tranny stuck in neutral???? #841987 10/17/07 04:22 AM
P
pineymudder Offline OP
i have an 88 v6 5 speed (r150)
its been shifting a little rough going into 4th and grinds just a bit when downshifting into any gear. coming home last night it didn't want to come out of third as i slowed down in front of my house, so i pulled it a little harder. it came out of gear but now is jammed up. no noise , no nothing.
my question is.... is there any way to re align whatever is out of line without pulling the tranny? is there a reputable rebuild kit for this tranny available? are the 3.4's tranny an r150?
sorry for the long post, thanks for any advise!!!!
stuck in the mud somwere in the swamps of jersey
Re: tranny stuck in neutral???? [Re: pineymudder] #841988 10/17/07 04:26 AM
4Crawler Offline
Might be worth pulling the shifter off and see what the shifter bushings look like:
- http://toyota.off-road.com/toyota/O...tring=Shift%20Lever%20Seat%20Replacement
Replacements from:
- http://www.marlincrawler.com/htm/transmission/trans_parts.htm
Re: tranny stuck in neutral???? [Re: pineymudder] #841989 10/17/07 04:29 AM
OOP'S Offline
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: tranny stuck in neutral???? [Re: pineymudder] #841990 10/17/07 09:45 AM
Adam F Offline
Might just be the springs on the clutch disc are shot. Mine did the same thing, but I had some noise from a broken spring.
97 4R, stock, daily driver
Re: tranny stuck in neutral???? [Re: pineymudder] #841991 10/17/07 12:28 PM
ACES_HI Offline
Could be either the master or slave are shot also.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: tranny stuck in neutral???? [Re: pineymudder] #841992 10/18/07 01:27 AM
Elbow_Greese Offline
All some good suggestions. Start with the easiest and work up from there.
I would start with the shifter bushing first. It's easy to get to and replace if it's bad.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: tranny stuck in neutral???? [Re: ACES_HI] #841993 10/18/07 01:29 AM
P
thanks for all of the replies!!! let me give you guys some recent history. about a month ago the master cylinder leaked inside the firewall, so i replaced both the slave and master cylinder. the truck shifting has been sloppy in past couple months. also the shifter isnt actually in neutral either... its jammed just not in a gear. (kind of in like the third gear area) i can only wobble it around with the slack in the bushing, not across the gear selection like nuetral usualy does. also if it was a problem with the clutch disc or preasure plate i should be able to shift it when the truck is not running.(wich i cant) i know my dads ford np435 jammed in third and wouldn't move,(the shifter not the truck) i pulled the top loader cover, re-aligned all of the shifting forks and he has been driving for over 3 months since then.
Re: tranny stuck in neutral???? [Re: pineymudder] #841994 10/18/07 02:47 AM
1
1986xtracab Offline
how's the clutch pedal feel?? possibly adjusting the free throw on the clutch pedal.
1986 xtra-cab 22re
stock everything
1991 bed
Re: tranny stuck in neutral???? [Re: pineymudder] #841995 10/18/07 03:49 AM
Adam F Offline
Yea...when I had problems, it shifted fine when the truck was not running.
Re: tranny stuck in neutral???? [Re: Adam F] #841996 10/18/07 11:03 PM
P
the clutch pedal feels great. since i did the master and slave it has never been better the whole time i owned the truck.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6441 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-10-24 02:37:06 UTC
