New here, project 85 yota vented brake conversion #842029 10/17/07 06:04 PM
4x4Brandon Offline OP
hello everyone, new to the forums. I've got an 85 4x4 with 22re motor. Just put in a new attarco motor with new head. Lifted 5inches (need rear springs, on blocks for now). i was wondering if anyone here has done a vented rotor conversion, i have everything to get it done, but was just curious if anyone has done it so in case i miss something or if there might be anything else i'll need. Of couse i have the rotors off a 81ish fj and calipers off an 88 4x4 yota. i'll be doing the install this weekend but was wondering if theres anything else i might need. Thanks for your help.
(added 10/19)I'll be installing this tomorrow, has anyone else done this conversion?
Re: New here, project 85 yota [Re: 4x4Brandon] #842030 10/17/07 06:22 PM
lethe Offline
i used some little 1/4" wheel spacers when i went to vented. the ifs calipers stick out a little past the hub mounting surface.
87' ext cab toy
Re: New here, project 85 yota [Re: lethe] #842031 10/17/07 06:49 PM
Good to know, thank you.
Re: New here, project 85 yota [Re: 4x4Brandon] #842032 10/19/07 11:44 PM
bump <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: New here, project 85 yota vented brake conversion [Re: 4x4Brandon] #842033 10/20/07 12:40 AM
Adam F Offline
It's pretty straight forward. Just bolt the stuff together. You may or may not need the spacers, depending upon the backspacing on your wheels. In my case, I had to buy the 1/4" wheel spacers, and grind some of the cooling fins off the calipers. Other than that, just bolt it up.
I forgot though, you might need a press to press the wheel studs in and out of the rotor. You can try using a hammer to get them out, but they may not budge. And its even harder to get the new ones back in. If you don't have a press, you can take them to a shop and they should be able to press them in for you for a couple bucks.
97 4R, stock, daily driver
Re: New here, project 85 yota vented brake conversion [Re: Adam F] #842034 10/20/07 06:45 AM
crap, i forgot about the wheel studs, lol. thanks for the info, i'm sure i'll look like this <img src="/forums/images/graemlins/shiner.gif" alt="" /> when i'm done. lol
Re: New here, project 85 yota vented brake conversion [Re: 4x4Brandon] #842035 10/20/07 05:14 PM
lethe Offline
i had some extra lug nuts i threaded onto the studs and beat on those to get them out. so if you have some extra lugs you could do it that way.
87' ext cab toy
Re: New here, project 85 yota vented brake conversion [Re: lethe] #842036 10/20/07 06:19 PM
4x4runner Offline
I was able to hammer the old studs out and the new ones in without any trouble. I did have to grind a little off the backing plates to fit the bigger caliper.
Re: New here, project 85 yota vented brake conversion [Re: 4x4runner] #842037 10/20/07 07:31 PM
Adam F Offline
See...some people have no problems. But I tried for an hour just to beat the old ones out with no luck. I HAD to use a press.
Re: New here, project 85 yota vented brake conversion [Re: Adam F] #842038 10/21/07 03:03 AM
rustylux Offline
I used a hi-lift and old wheel nuts to get the wheel studs out. Budget shop press at its best.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6382 MB (Peak: 0.7613 MB) Data Comp: Off Server Time: 2026-06-22 07:32:24 UTC
