Re: over heating while in 4x4
[Re: roman6_72]
#842056
10/18/07 12:40 PM
Hey.. I knew this old post would come in handy.. There is a burp picture about halfway down the thread.. Good luck!! LINK
88 Pickup,4x4, 2.6 L, AMC head, K&N Air filter, Aisin Hubs, Redline Oils everywhere, 94 Trooper wheels.
[Re: jdobbsj]
#842057
10/19/07 12:36 AM
Kewl, thanks for the tip Im gonna try it this weekend...Ill let you know if that solved my problem....Also, tried to replicate the overheating.....started to do the over heat while 4x4 at low speed as i cruised around the block a couple of times. Also, let the truck sit at idle and moderate over heating..turn on the A/C let it sit at idle and whamo over heated pretty bad! Im at a loss! More insight would be awesome.
[Re: roman6_72]
#842058
10/19/07 02:49 AM
Isuzu Moderator
If you got it to overheat not moving in the driveway, then you just ruled out the 4x4 system being part of the equation in my mind. Burp the system, make sure you don't have any obvious obstructions on/around the radiator, and see what happens.
If you're still getting the overheat after the burping, I think you're going to have to look at either a bad radiator or a bad fan clutch.
James
[Re: roman6_72]
#842059
10/22/07 04:38 PM
Roman, For what its worth.... My 99 rodeo LS was overheating during a trip to and from Utah. Nursed it there and back, but even after replacing the thermostat in Utah and taking the radiator off to have it checked & flushed still it overheated! Finally had to take it to a professional who had everything checked! Turns out my motor had blown a head gasket... a small area between layers of the gasket. Compression from one of the cylinders was messing up my coolant system! Motor warranty covered almost all of it thank God! Just my two cents worth Good Luck!
Glassen
"Glasspack" 1991 Rodeo LS 1999 Rodeo LS
[Re: jezeric]
#842060
10/23/07 08:46 PM
Thank you my Fellow AMERICANS for the insight! The 'BURP' worked! With respect, I appreciate all the genuine helpful responses from people across this great country of ours.
[Re: roman6_72]
#842061
10/26/07 07:25 PM
This might solve my overheating problem...I will try his burping thing tommorow
