trouble shooting help????? #842161 10/18/07 12:41 AM
mountain_warrior Offline OP
in my newly purchased 75 cj5 my engine runs great except when im driving on a non-stop street for more then 2 miles then i get a pulling feeling like its not getting gas it kinda feels like its not warmed up but i know it is and im not sure what it is so any help would be great
tia
cory <img src="/forums/images/graemlins/patriot.gif" alt="" />
1988 swb montero/pajero
1995 sr montero
Re: trouble shooting help????? [Re: mountain_warrior] #842162 10/18/07 03:59 AM
BigJim Offline
A "pulling feeling" ain't gonna get an answer... We need to know what a "pulling feeling" does to the Jeep. What does it do?
Re: trouble shooting help????? [Re: mountain_warrior] #842163 10/18/07 10:06 PM
BobRowe Offline
Your gasoline tank vent may be clogged. Try removing the gas cap (seriously) and running for that 2 miles or so, and see what happens.
Re: trouble shooting help????? [Re: BobRowe] #842164 10/19/07 10:35 PM
the pulling feeling sounds like brings my engine to idle and and im not getting very much or sometimes any gas but it never really stalls
cory
1995 sr montero
Re: trouble shooting help????? [Re: mountain_warrior] #842165 10/19/07 11:40 PM
BigJim Offline
cory
Change the fuel filter and go drive it!
Re: trouble shooting help????? [Re: BigJim] #842166 10/20/07 02:25 AM
i've already changed it but i drove for about 3 miles without my gas cap and now its running way better, but what did that do<img src="/forums/images/graemlins/confused.gif" alt="" />
tia
cory
1995 sr montero
Re: trouble shooting help????? [Re: mountain_warrior] #842167 10/20/07 04:29 AM
BobRowe Offline
Some gas tqnks vent through the gas cap. There must be a vent, or else the fuel pump will eventually create a vacuum in the tank, impeding good fuel flow. If you take the gas cap off, and it runs better, it's an indication that the gas cap vent may be clogged. Sometimes, just banging the cap around when you're removing and storing it will clear the vent, and it will work when you re-install it. But if it starts running bad again, invest a few bucks and get a new gas cap just to eliminate the cap as a possible cause of the problem.
A partially clogged fuel filter can also cause a similar problem. If you have both a bad cap and a partially clogged filter, you can get some weird indications.
Given the inexpensive cost of filters and caps, I'd change them both and monitor the engine operation for a while.
Re: trouble shooting help????? [Re: BobRowe] #842168 10/20/07 07:38 PM
ok cool thanks alot <img src="/forums/images/graemlins/kewl.gif" alt="" />
cory
1995 sr montero
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6208 MB (Peak: 0.6994 MB) Data Comp: Off Server Time: 2026-06-23 13:04:32 UTC
