Clutch And Valvecover Gaskets #842169 10/18/07 03:18 AM
89toyOn35s Offline OP
Soooooo....
Early this week i began to notice my clutch slipping. <img src="/forums/images/graemlins/angry.gif" alt="" />
So this weekend i am planing on replacing it along with replacing the valevcover gaskets. <img src="/forums/images/graemlins/scared.gif" alt="" />
1: Is there anything i should read up on in replacing the clutch?
2:What is a good brand to buy and where from?
3:Also on the valvecover gaskets what brand and where to get them?
Also is there anything i should replace while i am in the top part of the motor or transmission? thanks
Joe
Re: Clutch And Valvecover Gaskets [Re: 89toyOn35s] #842170 10/18/07 03:33 AM
Sorry i guss i could tell you it is a 89 toy 3.0
Re: Clutch And Valvecover Gaskets [Re: 89toyOn35s] #842171 10/18/07 03:36 AM
O
oldsub86 Offline
I would go get original parts if I were you. I replaced the clutch in my 95 4Runner with an aftermarket kit and have regretted it ever since. I am just in the process of putting in a new Toyota clutch. Got the tranny back in and am just putting everything else back together. Starter is a pain - just did it tonight. Good thing I don't have to drive the Runner as I have had it in parts for more than a month. Also got valve covers as oil is running down the back of the block. Going to change the pcv and grommet while the plenum is off as it will be much easier.
Randy
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: Clutch And Valvecover Gaskets [Re: oldsub86] #842172 10/18/07 03:38 AM
Adam F Offline
Go to www.jtoutfitters.com call them and ask them for an "asco" clutch. It's the brand Toyota uses.
Like it was said before, replace the pcv valve and grommet while your in there.
97 4R, stock, daily driver
Re: Clutch And Valvecover Gaskets [Re: Adam F] #842173 10/18/07 04:22 AM
OOP'S Offline
Make sure to have he flywheel re-surfaced.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clutch And Valvecover Gaskets [Re: OOP'S] #842174 10/19/07 01:49 AM
speaking of starters Mine has been loose since i bought it ican move it up and down and back and forth i have tried to tighten the botls but they are already tight it looks to be a new starter. and the brakets for the wireing harness are just hanging there would the brakets not being in the starter bolts cause this or could they not have put it on right in the first place thanx
also what other gaskets should i get when removeing the intake ect. to get to the valvecovers the only kit that has everything is an head hasket set and that is over $225.00
the valvecover gaskets arent but $19.99. thanx
Re: Clutch And Valvecover Gaskets [Re: 89toyOn35s] #842175 10/19/07 02:05 AM
Adam F Offline
Your problem could be the "new" starter. Unless its OEM, it's junk. I've seen where they don't bolt up very well or have different mounting holes.
Only gasket you need is the upper plenum gasket. Oh and I think there might be a EGR gasket and a cold start injector gasket.
Re: Clutch And Valvecover Gaskets [Re: Adam F] #842176 10/19/07 02:11 AM
hey Adam On the website you gave me it has the clutch Clutch Kit 88-95 Toyota Pickup Truck 4Runner V6 3VZE T100 $109.95
Part Number:16059A
Brand new clutch, pressure plate, release bearing, pilot bearing, and alignment tool for your Toyota. All parts are new, not remanufactured. Kit even comes with the pilot bearing (most don't). is this what you ran in yours and does it prform good
Re: Clutch And Valvecover Gaskets [Re: 89toyOn35s] #842177 10/19/07 02:24 AM
Adam F Offline
Yea thats what I've been running for the past few years. Works great. Although I did order it off the web, and got some off brand. I called the shop up and specifically asked for an ASCO brand clutch.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6244 MB (Peak: 0.7279 MB) Data Comp: Off Server Time: 2026-07-14 21:47:52 UTC
