TIME FOR SOME BOOST........ #842189 10/18/07 11:43 AM
A
Adskia Offline OP
wellone and all here is the start of my turbo fit up.....
have been flat out at work and i havent done much....
and am still waitin for some more bits to arrive.....
first of all you need to make some ROOM for the the turbo.......
the battery in the oz ones sits right against the firewall on the left hand side of the engine bay.....to make romm(and a heap at that)..you need to relocate the battery longways so it sits against the left guard.......made a few brackets.....and mounted the battery tray like so and all you do is lengthen the positive cable ....used huge battery cable for good power supply .......seems to have made a difference to performance just by doin that ......but i dont think so....the battery was disconnected for a while and when i connected it , its goin heaps better .....so i think i cleared some gremlins hey.....haha..
more in a couple of days .....Ads <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
THE POWER TO SUPRISE.
Re: TIME FOR SOME BOOST........ [Re: Adskia] #842190 10/18/07 05:30 PM
blitz Offline
its a start, keep us posted.i may have to be a copycat. <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: TIME FOR SOME BOOST........ [Re: blitz] #842191 10/18/07 11:39 PM
Everet Offline
Looks great...what type of heat shield are you going for...stainless custom?
Keep us posted with details and pics.
Everet <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: TIME FOR SOME BOOST........ [Re: Adskia] #842192 10/19/07 10:14 PM
DennisThompson Offline
What turbo are you using. I have a low milage turbo out of a 89 Ford Probe that I was planning on installing intill I sold the Kia to my boy. Now that I am buying the kia back I will try to install it after winter. My oldest by and one of his friends good at turbo installs. My boy just built up a Sportage engine and strocked it to 2.2L with a Probe crank for his 89 Probe GT. He is breaking it in with out the turbo and can still out run most of the Honda's around here. When he gets the turbo on he is hopping for mid to high 11s in the quarter mile. He was running in the high 13s with a stock FE3 and a Subaru WRX turbo in his non GT Probe but could not get traction intill half way through 3rd gear. Anyway I was just curious. Keep us posted on your install.
Dennis
Re: TIME FOR SOME BOOST........ [Re: DennisThompson] #842193 10/19/07 10:33 PM
A
Adskia Offline OP
sounds like im on a good thing then dennis.......am usin a wrx turbo.....of an sti.......
Re: TIME FOR SOME BOOST........ [Re: Adskia] #842194 10/19/07 11:04 PM
flyboy367 Offline
you still want that header??
1995 nissan maxima se, 5spd short throw, aluminum flywheel and crank pully, stage 3 clutch, custom ported top end, full 2.5 exhaust jdm front end
Re: TIME FOR SOME BOOST........ [Re: flyboy367] #842195 10/21/07 03:48 AM
A
Adskia Offline OP
dont need it now F/L........spend the money and had made up a manifold .....thanks anyway.....
cheers Ads
Re: TIME FOR SOME BOOST........ [Re: Adskia] #842196 10/24/07 12:43 PM
A
Adskia Offline OP
will have an update in the next few days....... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: TIME FOR SOME BOOST........ [Re: Adskia] #842197 10/25/07 06:24 PM
logansportage Offline
Can you post a pic of the entire engine bay please.
Thanks.
Re: TIME FOR SOME BOOST........ [Re: logansportage] #842198 10/29/07 09:09 PM
A
Adskia Offline OP
well......a little update guys.........have the flange plate ready for some pipes to be welded to it ....here is some before and after shots.......
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6374 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-06-09 21:59:36 UTC
