My 1990 4Runner #842323 10/18/07 09:33 PM
code33 Offline OP
Approx. 230k original miles on 3VZE motor & tranny. Failed smog a few years ago because of a burnt valve and has been non-op since in the garage.
Open ended question... So what should I do with it?
Thinking new motor... How much is it going to cost?
Classifieds & Suzuki Moderator
Re: My 1990 4Runner [Re: code33] #842324 10/18/07 10:06 PM
Dok Offline
5vze swap smile Probably doable for <$3k if you get a deal on a motor...
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: My 1990 4Runner [Re: Dok] #842325 10/18/07 10:10 PM
code33 Offline OP
Would be nice but don't want to deal with new exhaust and wiring. Already have $$$ into 3VZE headers.
Re: My 1990 4Runner [Re: code33] #842326 10/18/07 11:17 PM
Staceman Offline
Replace it with a "good-used"?
This one has only 95K miles.....
You could run it while you take your time rebuilding the old one?
Engine
Toyota 4Runner -6 CYL (3VZE ENG, VIN V, 4TH DIGIT)-,10 95,000 A PR7323 $800 Cornell's Used Auto Parts USA-NY(Greenfield-Center) Request_Quote 1-518-893-0151 Request_Insurance_Quote
Re: My 1990 4Runner [Re: Staceman] #842327 10/18/07 11:17 PM
Staceman Offline
Or..
swap the motor, then sell it, use the cash on something else.
Re: My 1990 4Runner [Re: code33] #842328 10/19/07 12:43 AM
Snowtoy Offline
If you plan to keep the Runner, I would pull the block and rebuild it. I would bore the block and consider some head work. This along with the headers, a moderately open exhaust, and a better intake should give you good results. If you do the work yourself it should come in under $2k, about $1500-2k cheaper than doing an engine swap.
This is assuming you have a 5-spd and not an auto. If you have an auto tranny, I would sell the Runner for what you can get and buy a 3rd gen w/the 3.4. You can find them starting at around $4-5k
Re: My 1990 4Runner [Re: Snowtoy] #842329 10/19/07 02:17 PM
Dok Offline
http://engnbldr.com/toyota_30_v6.htm
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: My 1990 4Runner [Re: code33] #842330 10/19/07 04:13 PM
ErikB Offline
Toyota Moderator
I would bet that that bottom end is still in pretty good shape. I would probably just rebuild the heads.
As my grandpa used to say, "If it ain't broke, don't fix it!" <img src="/forums/images/graemlins/notooth.gif" alt="" />
http://home.4x4wire.com/erik
Re: My 1990 4Runner [Re: ErikB] #842331 10/19/07 10:03 PM
jmsdad Offline
Hi Ken,
Ditto on what ErikB said. Just rebuild the heads with new gaskets/head bolts and you're good to go. I rebuilt the top end on my Dad's 94 3 years ago (~90K miles ago) and it's still going strong. Cost was under $500 IIRC.
Re: My 1990 4Runner [Re: jmsdad] #842332 10/19/07 11:34 PM
O
OutlawMike Offline
If you go the rebuild route, make sure you get new head bolts, do not re-use the old ones.
I rebuilt the top end on my '89 V6 3.0 back in the spring. It had dropped a valve seat on the #6 intake. I had the head shop put in all new exhaust valves, new guides, cut the 11 good seats, and install an oversized seat to replace the one that dropped.
It was $950 with a complete Felpro gasket set for the entire motor, new head bolts included from the head shop, and they tanked/blasted my intake and air plenum. I pulled the motor to replace all the seals while I was in there.
If you do the job, and you are going to keep the rig, you would want to do the following:
timing belt
tensioner
tensioner spring
water pump
thermostat
knock sensor jumper wire
hoses/belts
Possible things to replace:
Knock sensor (under the intake, expensive to replace, but hard to get to later).
idler pulley, if worn and notchy
You could quickly get up to $1200 or so for parts and labor on the simple head rebuild.
Mike
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6408 MB (Peak: 0.7611 MB) Data Comp: Off Server Time: 2026-07-14 21:49:15 UTC
