warn full float kit for dana 35 #842400 10/19/07 04:05 AM
cbrazor Offline OP
warn ful float kit dana 35 are these kits any good is there any streanth gain or r they junk
92 jeep yj re 4 inch lift revolver shackels front and rear 36 inch shocks in front 27 inch in rear 34 swampers ltb 2inch wheel spacers
Re: warn full float kit for dana 35 [Re: cbrazor] #842401 10/20/07 08:11 AM
BobRowe Offline
I'm not familiar with the Dana 35 axle, since I'e never had one.
But I do have an AMC 20 axle in my CJ7. I initially removed the OEM two-piece axles and replaced them with Moser one-piece axles. I never had a problem with the Mosers, but I never liked the bearing set-up, and I wanted to be able to easily flat-tow the Jeep.
So I removed the Mosers and installed a Warn full floater kit in the AMC 20 axle. The kit is very well made. The axleshafts are stronger than the Mosers. The bearing setup is the same as the front axles on the Dana 30. In fact, Warn wisely used the identical inner and outer bearings and races. So I can carry one spare set in my onboard toolbox, and it will fit any of the four corners. And having strong internal-type locking hubs is a real bonus -- just unlock them to flat tow.
Re: warn full float kit for dana 35 [Re: cbrazor] #842402 10/20/07 04:05 PM
F
Fred Blackstone Offline
The Warn full Float kit is fine, it's the weak Dana 35 axle that is the problem with that particular setup. I admit that I did this upgrade many years ago on my 94 YJ; it'll take the weight off the tube housing. However, the Dana 35 axle design and thin tube housing will not withstand difficult rocky trails but perhaps only a few years, at best, and eventually fail. I was lucky; I was able to drive home after completing Calamity Canyon in Montrose, CO, some 200 plus miles. The driverside tube housing was leaking gear lube and spinning freely in the rear differential. I suspect that the traction bar welded onto the tube housing was the only thing keeping the tube housing in place.
Re: warn full float kit for dana 35 [Re: cbrazor] #842403 10/21/07 05:40 PM
DBL_DTY97TJ Offline
What Fred said.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: warn full float kit for dana 35 [Re: DBL_DTY97TJ] #842404 10/21/07 07:31 PM
80CJ Offline
In addition to what has been already said, the D35 has a small ring and pinion. So you can install a Detroit in the diff but the small R&P are still there being fastened to the diff by only eight 3/8 inch bolts.
Re: warn full float kit for dana 35 [Re: 80CJ] #842405 10/22/07 04:20 PM
superdawg Offline
The bottom line is spending good money for bad.
D35, is a joke axle, no doubt. Every dime spent on it is wasted. Now lets talk full float kits, the 44 kit is not terrible, but when you look at it like...Here you go replacing solid, heat treated, steel, with plastic and pot metal, you simply need your head examined. Sure, you flat tow it and turning hubs out is easier than un bolting the driveshaft, I'll give you that one. The real question is what do you do once you unhook the tow bar? Drive to the grocery store? Or wheel a hardcore trail...? I'll take unbolting the shaft (not tying it up under the rig either) completely. If you drive it and don't tow it, why would you ask about ff kits at all?
SD
Re: warn full float kit for dana 35 [Re: superdawg] #842406 10/22/07 07:02 PM
Brown81CJ5 Offline
Aren't FF's a lot easier to change if broken?
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: warn full float kit for dana 35 [Re: superdawg] #842407 10/23/07 02:55 AM
cbrazor Offline OP
ok thanks alot you all been a lot of help <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: warn full float kit for dana 35 [Re: cbrazor] #842408 10/23/07 03:25 PM
superdawg Offline
In other words, "I'll do it my way and forget I ever asked"
In answer to the question if FF are easier to change? Not really, mainly because you still have to fish out chunks and the hub explodes when the axle breaks anyway.
Oh wait, those hubs explode just looking at them wrong.
SD
Re: warn full float kit for dana 35 [Re: superdawg] #842409 10/23/07 06:27 PM
Brown81CJ5 Offline
SD he only asked for people's opinion on them. He never said he was going to get the kit or not. He just wanted to hear what people had to say about it.
In no way was he saying screw you guys, I'm going to get the kit anyway. He just said thanks for the input. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Gun it and run it!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6356 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-10-21 20:43:53 UTC
