1996 and newer taco..... #842444 10/19/07 07:35 AM
F
flyinhawaiian Offline OP
howzit everyone. i read somewhere that the 1996 and newer tacos 4x4 rr axle has factory e-lockers. is this true? and has anyone considered putting that under a 1st gen truck? would it work? i'm asking cuz i have 83 4x4 and would like to try if doable. Thanks!!!
Re: 1996 and newer taco..... [Re: flyinhawaiian] #842445 10/19/07 01:23 PM
superv43 Offline
Lots of people have done this. There is even an article in the tech section here: Retrofit Elocker in 8" axle
Re: 1996 and newer taco..... [Re: superv43] #842446 10/19/07 08:53 PM
F
thanks for reply. i browsed that article a while back but thought it was too much work. so my thoughts are would you be able to swap out the differential assy as a whole? would spring perch line-up, i guess the output flange would have to be re-drilled or changed...???
Re: 1996 and newer taco..... [Re: flyinhawaiian] #842447 10/19/07 08:56 PM
ErikB Offline
Toyota Moderator
The axle will bolt right in. The brake stuff (e-brake and brake lines) is on opposite sides, but that can be fixed.
And yes, on a 1st gen, you'd have to redrill the driveshaft flange.
The Tacoma axle is also about 5" wider but the perch width is the same.
http://home.4x4wire.com/erik
Re: 1996 and newer taco..... [Re: flyinhawaiian] #842448 10/20/07 12:41 AM
Adam F Offline
It's actually easier to just modify your housing. Here's my install...
http://home.4x4wire.com/adamf/88/elocker.htm
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6056 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-06-10 01:36:25 UTC
