Please help identify vacuum line connection #842457 10/19/07 05:41 PM
Glassen Offline OP
Will some one with a 1999 Rodeo 3.2L take a photo of the vacuum switching valve at the brear drivers side of the engine. The one directly behind the fuel pressure regulator.
It is mounted on a bracket one the air plenum and has two vacuum lines to it, as well as teh electrical connector. Mine broke several months ago and I had to temp fix it by hooking three lines together with a "T" fitting to eliminate the vacuum leak. I now have the new valve but for the life of me I cant get the hoses in the right spot. Should have marked them with tape.....
Thanks Guys .... And ladies
Paul
"Glasspack"
1991 Rodeo LS
1999 Rodeo LS
Re: Please help identify vacuum line connection [Re: Glassen] #842458 10/21/07 04:41 AM
9
99_Fronty Offline
Well I took a photo but no idea how to post it. Send me a message with your email and I'll mail it.
Cheers,
Re: Please help identify vacuum line connection [Re: Glassen] #842459 10/21/07 06:40 AM
Gizzy42 Offline
I took these for someone else a while ago. hope its what you need.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Please help identify vacuum line connection [Re: Glassen] #842460 10/21/07 07:17 AM
Glassen Offline OP
Thank you Guys,
Do you really know what that vacuum switching valve is for .......like what circuit is it?
I know what it is and how it works ....It opens and closes to turn on and off the vacuum for something... Its the something that I was also trying to figure out. I know I found it broke after i had the whole intake manifold and air plenum apart for thermostat replacement. I was troubleshooting the cause for such ***** gas mileage on my drive back from Utah right after teh maintenance.
Any one know what it it is for ?
Glassen 1999 Rodeo LS
"Wishing I had the money for a Calmini lift kit"
"Glasspack"
1991 Rodeo LS
1999 Rodeo LS
Re: Please help identify vacuum line connection [Re: Glassen] #842461 10/21/07 09:59 AM
9
99_Fronty Offline
If I'm not mistaken this actuator works a linkage on the back of the manifold that turns two shafts running lengthways through the manifold. Each shaft has three butterfly valves on it that close off one of two inlet runners to each cylinder. I believe it opens around 3000 rpm. Gives higher air velocity into the cylinder at low rpm.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6055 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-06-21 13:39:43 UTC
