sunroof......................leaks
#842615
10/20/07 06:49 AM
anyone have any problems with a leaky sunroof? how to fix? where to fix?
Re: sunroof......................leaks
[Re: VERRELLI]
#842616
10/23/07 09:43 PM
No leaks but I saw the guys at VIB on Kingsway tear out two sunroofs from a pair of Pajero's back in July when I was scouting for one.
They pulled the headliner out and went it from the bottom/inside as far as I know. It seems that once the rails start to rust, it gets bad to worse fast and leaking can't be stopped. Hope I'm wrong. Take a peek.
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on 89 Montero - Project 92 Pajero Exceed - Gone to a good home 92 Delica Chamonix - Gone to a good home
[Re: jfarsang]
#842617
10/24/07 12:27 AM
I would silicone the sunrood before I rip the headliner out...thats too much work for me, but im lazy lol.
[Re: torquemonster]
#842618
10/24/07 12:50 AM
I think the drains are plugged. I wanna blast some air in there to blow out dirt but I've read that this might blow the plastic hose on the inside apart. I've got to find another way to clean this gently.
[Re: torquemonster]
#842619
10/24/07 01:08 AM
Check the two drain outlets on each side at the front. Mine were plugged with accumulated debris, if these are draining properly a slow leak shouldn't get in the truck. There is a small rubber tube that runs through the body from the openings. I ran a small wire down as far as I could to start an opening, then blew some air down. {On one side I had to open the headliner and pull the hose off the metal line leading from the sunroof opening then run the wire.} This got a little flow started I then kept pouring water in and they cleaned out. solved my leak problem
[Re: gtk68]
#842620
10/24/07 01:16 AM
If you shove a wire down there, how long does it have to be? Will a clothes hanger do it?
[Re: VERRELLI]
#842621
10/24/07 01:58 AM
You will need a very small gauge flexible wire, small but stiff enough to push through the first bends and twists if it won't go then remove a piece of headliner directly below and get access to the rubber tube.
[Re: gtk68]
#842622
10/25/07 04:05 PM
I had a leak in the sunroof last year. All I did to fix it was silicone where the glass and the metal frame meet. Solved it right away.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6205 MB (Peak: 0.6984 MB) Data Comp: Off Server Time: 2026-10-24 07:18:06 UTCValid HTML 5 and Valid CSS
