Instrument Panel Issues #842696 10/20/07 08:26 PM
Coastie1971 Offline OP
I have a 1998 Jeep Wrangler Sahara Edition. The instrument panel has just started acting weird. When driving down the road the instrument gauges goes completely dead, no fuel, alternator, RPM, speedometer, nothing. It lasts like this for maybe a few miles and then it goes back to normal like nothing was ever wrong. Has anyone experienced this before?
Re: Instrument Panel Issues [Re: Coastie1971] #842697 10/21/07 04:58 AM
BobRowe Offline
It sounds like the ground to your instrument panel is loose. Temporarily ground it with an extra wire and see if that solves your problem. If that does, then find and fix the OEM ground.
Re: Instrument Panel Issues [Re: Coastie1971] #842698 10/21/07 05:26 PM
DBL_DTY97TJ Offline
Yup. It was the ground ribbon under the hood.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5919 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-06-07 11:31:15 UTC
