repacking bearings #842808 10/21/07 09:46 AM
W
walktastic Offline OP
so my local shop has told me that both of my wheel bearings need to be repacked. i was wondering how strenuous a task this is and if a weekend warrior mechanic can do it without the special tools?
V6 pickup 4x4, 385,000 miles and still ticking
Re: repacking bearings [Re: walktastic] #842809 10/21/07 03:38 PM
dknight Offline
It is an easy but time consuming job. Probably a good idea to do it at least once yourself so you know how. Easily done with hand tools in your driveway. You do need a 54mm (or 2 1/8") socket to remove large nut (some people do this with a chisel, but that is a hack imo). A brass drift can be useful for removing cone washers.
Re: repacking bearings [Re: dknight] #842810 10/21/07 05:59 PM
Vanishing_Point Offline
The correct socket is only about $12.00. Repacking isn't too hard. Put some grease on your palm and use a scooping motion to push the grease through the roller cage. Remember to use a spring scale to set up the preload. I used a fish weight scale.
Re: repacking bearings [Re: Vanishing_Point] #842811 10/21/07 06:15 PM
RatLabGuy Offline
Just be ready with a whole roll of paper towels. It's mesy, you're going to end up with grease everywhere.
Question Reality.
Re: repacking bearings [Re: RatLabGuy] #842812 10/21/07 06:36 PM
dknight Offline
Here is a tip. Make note of what tools you need. Carry them in your truck in case you need to do similar work away from the home.
You should clean out the old grease before you pack in the new. Yes, it is a messy job.
If you do not have a factory manual for your truck, get one. Carry it with you.
Re: repacking bearings [Re: dknight] #842813 10/21/07 06:48 PM
1
1986xtracab Offline
while your doing it, using a good synthetic grease is a good idea.
1986 xtra-cab 22re
stock everything
1991 bed
Re: repacking bearings [Re: RatLabGuy] #842814 10/22/07 01:05 AM
1
1FastSS Offline
Some rubber gloves from HarborFreight Tools are excellent. When you done, peel them off and no messy hands. Make sure you replace the seals as well.
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: repacking bearings [Re: 1FastSS] #842815 10/22/07 03:40 AM
W
i heard that removing the cones can be a bear. any tips on getting those out? and what is a brass drift?
Re: repacking bearings [Re: 1FastSS] #842816 10/22/07 03:43 AM
OOP'S Offline
Here is a link that will walk you through it. It is for an 85 solid axle but the specs and procedure are the same for IFS. Go to page FA-43 to FA-47.
http://www.lukemiller.org/toys/1985_toyota_4wd_front_axle_FSM.pdf
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: repacking bearings [Re: walktastic] #842817 10/22/07 05:09 AM
4Crawler Offline
http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml#ConeWasherRemoval
Brass drift if basically a long brass (or other soft metal) rod that won't damage the steel studs:
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6377 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-05-29 23:50:49 UTC
