20R from 2WD swap into 4WD, help!!! #842870 10/21/07 08:43 PM
cokeslingin Offline OP
Is this a straight swap or do i need to change anything to make it work???
Re: 20R from 2WD swap into 4WD, help!!! [Re: cokeslingin] #842871 10/23/07 02:38 AM
Elbow_Greese Offline
Check the clearance of the oil pan. Other than that, should be the same.
If the oil pan is too close, you'll need to change the pickup tube as well.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: 20R from 2WD swap into 4WD, help!!! [Re: Elbow_Greese] #842872 10/23/07 02:54 AM
A
Anthony_89 Offline
I wana see this. that sounds awesome!!
Re: 20R from 2WD swap into 4WD, help!!! [Re: cokeslingin] #842873 10/23/07 03:00 AM
kewlynx Offline
x 2 on what Todd mentioned, as usually a 22Rx from a 2wd donor into a 4wd rig takes the 4wd oil sump and pan to make it work. And on the dipstick tube, there will be an inch of difference (eg, 22R in Celicas), so make sure you check.
Give the engine mounts a good look too, esp if the 4wd is >'83, due to frame differences.
If you do not have vacuum diagrams, make sure you mark stuff. <img src="/forums/images/graemlins/shame.gif" alt="" />
**ubi apis- ibi salus**
Re: 20R from 2WD swap into 4WD, help!!! [Re: kewlynx] #842874 10/23/07 04:48 AM
Because i don't know, do i have to worry about a spline # difference between the 4WD tranny and the 2WD motor? If there is how do i fix this issue??
Re: 20R from 2WD swap into 4WD, help!!! [Re: cokeslingin] #842875 10/23/07 04:51 AM
kewlynx Offline
What's it going into, aside from a 4wd? You've got 3 tranny choices. Also check our Toyota FAQ in the header above for tranny info.
Re: 20R from 2WD swap into 4WD, help!!! [Re: cokeslingin] #842876 10/23/07 07:40 AM
Davepet Offline
Now you've got me worried..... The splines on the tranny mesh with the clutch disc, not the engine. *IF* there is a difference, the worst case is you might need to figure out if the 4wd clutch disc will work with the 2wd flywheel/pressure plate, or if the 4wd flywheel will bolt to the 2wd crankshaft.
It's almost certainly do-able, afraid I have no info on what hoops you may need to jump through...
Dave
Re: 20R from 2WD swap into 4WD, help!!! [Re: Davepet] #842877 10/23/07 07:45 AM
kewlynx Offline
In that case too, a parts lookup would be a good idea to check interchangeability.
Re: 20R from 2WD swap into 4WD, help!!! [Re: Davepet] #842878 10/24/07 03:58 AM
Pretty much new to any major work (ie. replacing the motor) in general. Thats why I came to this forum to get help and ideas from people who know what they're talking about. So thanks to all who contributed with your experience and knowledge!!! <img src="/forums/images/graemlins/cheers.gif" alt="" /> I'll let yall know how things go. Motor is being dropped at my door on sunday.
Re: 20R from 2WD swap into 4WD, help!!! [Re: kewlynx] #842879 10/24/07 04:05 AM
Stock L43 as far as I can tell. The motor is coming as a package deal and am getting another L43 and not sure which 5 speed manual. Might have one big swap on my hands here if I can get the info about the 5 speed. Or maybe it'll get posted for sale on the forum for any of my NOR*CAL neighbors. <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6364 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-06-22 07:31:57 UTC
