speed sensor 89 trooper #843290 10/23/07 07:51 PM
Mudking4717 Offline OP
Im buying a tow bar fro my 89 trooper and wanted to know if I tow it if it would still run the speedo. Or should i just get tow dolly?
Re: speed sensor 89 trooper [Re: Mudking4717] #843291 10/23/07 08:28 PM
mlclark Offline
Isuzu Moderator
I think adding miles to an 89 Trooper is the least of any concerns.
You will need to pull the driveshaft and tie it up out of the way. The TC (specifically the rear output bearing and bushing) does not get sufficient lubrication in neutral with the driveshaft spinning.
Michael
Re: speed sensor 89 trooper [Re: mlclark] #843292 10/25/07 08:35 PM
Thanks a lot I didn't know that you had to pull the drive shaft off. I mite be getting a tow dolly which I think will work better. Thanks A lot
Re: speed sensor 89 trooper [Re: Mudking4717] #843293 10/26/07 12:28 AM
mlclark Offline
Isuzu Moderator
Even with a tow dolly, you will need to tow it backwards and have the front hubs unlocked.
Michael
Re: speed sensor 89 trooper [Re: mlclark] #843294 10/27/07 07:18 AM
That's what I was going to do. I have auto hubs it should be no problem
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6072 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-07 04:26:57 UTC
