speed sensor 89 trooper
#843290
10/23/07 07:51 PM
Im buying a tow bar fro my 89 trooper and wanted to know if I tow it if it would still run the speedo. Or should i just get tow dolly?
Re: speed sensor 89 trooper
[Re: Mudking4717]
#843291
10/23/07 08:28 PM
Isuzu Moderator
I think adding miles to an 89 Trooper is the least of any concerns.
You will need to pull the driveshaft and tie it up out of the way. The TC (specifically the rear output bearing and bushing) does not get sufficient lubrication in neutral with the driveshaft spinning.
Michael
[Re: mlclark]
#843292
10/25/07 08:35 PM
Thanks a lot I didn't know that you had to pull the drive shaft off. I mite be getting a tow dolly which I think will work better. Thanks A lot
[Re: Mudking4717]
#843293
10/26/07 12:28 AM
Isuzu Moderator
Even with a tow dolly, you will need to tow it backwards and have the front hubs unlocked.
Michael
[Re: mlclark]
#843294
10/27/07 07:18 AM
That's what I was going to do. I have auto hubs it should be no problem
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6056 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-06-07 07:19:21 UTCValid HTML 5 and Valid CSS
