Loose Speedometer Needle #843556 10/24/07 11:24 PM
T100mike Offline OP
I have a 97 T100 and my speedometer needle is loose. I had it checked out at my local mechanic and he told me the cable is tight. He said its most likely the needle itself and he couldn't fix it or didn't want to, so I should go to a Toyota dealer. I was wondering if anyone has run into this problem and knows how much it might cost. I know its probally going to be pretty pricey since they have to take the dashboard apart. Also was wondering if anybody has had the problem and fixed it themselves. Is there a lot involved?
Re: Loose Speedometer Needle [Re: T100mike] #843557 10/24/07 11:28 PM
Jake97T Offline
just a dry speedo cable most likely, havent priced them, most of us just live with it if its just bouncing a bit...
Re: Loose Speedometer Needle [Re: Jake97T] #843558 10/24/07 11:31 PM
T100mike Offline OP
Bounces more then a little bit, its off by about 10mph. In the cold weather it stays up on 120mph.
Re: Loose Speedometer Needle [Re: T100mike] #843559 10/25/07 02:03 AM
garym Offline
It is not really that hard to take that whole unit out. I can send you a step by step process if you want it. Is the needle actually cocked to one side and dragging on the background piece or does the whole mechanism seem to be gummed up? For some reason everyone, myself included, experiences the thing bobbing around, especially at low speeds.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Loose Speedometer Needle [Re: T100mike] #843560 10/25/07 02:12 AM
garym Offline
Might help
Previous Post
02 Camry LE
2008 Yaris
Re: Loose Speedometer Needle [Re: garym] #843561 10/25/07 04:30 PM
T100mike Offline OP
That would be great if you could send me some info on how to do it. The needle justs seems loose. When I'm going about 20mph its on or around 30mph and bobbing around. I can deal with a little bobbing, but this is way to much. Like I said earlier when its cold out its pinned to about 120mph and bobbing. Since its my daily driver I want to be able to fix it.
1995 T100 4x4 DLX EXC
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6074 MB (Peak: 0.6767 MB) Data Comp: Off Server Time: 2026-06-23 21:16:43 UTC
