Lift pump #843630 10/25/07 05:37 AM
8
89Diesel Offline OP
Does anyone know what (or if?) there is a lift pump on either a D50 or Ford Ranger for the diesel? If so, what pressure does it run at, and where is it mounted? I've looked and asked at parts sites and stores and cannot find even a mention of a pump, let alone a part #. So far everything seems to point to it being part of the injection pump, like a big Cummins or John Deere. My '89 D50 was a gasser and the diesel engine came from a wrecker out of an '86 Ranger.
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Re: Lift pump [Re: 89Diesel] #843631 10/25/07 05:00 PM
MarkG Offline
I have a paper copy of the 1983 parts manual. I'll try to check it in the next few days.
Re: Lift pump [Re: MarkG] #843632 10/25/07 05:23 PM
8
89Diesel Offline OP
I'd really appreciate that. Thank you. I've kinda checked all over, and come up with nothing.
Re: Lift pump [Re: 89Diesel] #843633 10/26/07 12:52 AM
torquemonster Offline
there is no lift pump...the injection pump does it all!!!! you will have to completely clean your gas tank before you fill it with diesel!!!!! and make sure you plumb up a spin-on fuel filter...the 2.6 Ram 50 tiny fuel filter is pretty much useless....
Re: Lift pump [Re: torquemonster] #843634 10/26/07 02:25 AM
8
89Diesel Offline OP
Thank you. I was hoping that was the case. This engine was out of a Ranger and has a square steel filter about 6" high X 3" wide X 3" deep.
Re: Lift pump [Re: MarkG] #843635 11/06/07 03:57 AM
MarkG Offline
It's been a long few days. <img src="/forums/images/graemlins/frown.gif" alt="" />
There is no fuel pump at/in the fuel tank. As stated above, the injection pump does it all.
Re: Lift pump [Re: MarkG] #843636 01/31/08 08:45 PM
Smeez Offline
There is a fuel lift pump on the Ford Ranger with the 4d55t. It is located almost right underneath the ip and is bolted to the inside of the drivers side frame. It's a cylindrical pump wrapped in insulation.
Pump specs
Pressure Rating:3.8 - 5.7
Gallons Per Hour:16.8
Napa # Mitsubishi Pump NFPP74029
Napa # Napa Pump TFP2P74029
Both pumps are rated the same for gph and pressure.
I need to change my lift pump and for the same price as the original pump can get a lift pump that is rated for 6 to 4.5 psi and 34 gph. If I make the switch to a more powerful lift pump will I need to make other adjustments to the vehicle, adjust the ip? Is this a good modification to increase performance and power? What tunings need to be done to accommodate for the extra lift?
1986 Ford Ranger 2.3l 4d55t Turbo Diesel 4X4 w/ 5spd
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6221 MB (Peak: 0.6963 MB) Data Comp: Off Server Time: 2026-05-29 21:12:06 UTC
