Adjusting Valves on 22re #843637 10/25/07 06:43 AM
P
pdonahue Offline OP
I've been posting alot lately, but you guys really help. I love this site. Anyway, I recently replaced my timing chain etc. in my '85 4runner 22re, and it quieted the motor down alot. Now I'm on a preventative maintainence kick, and I noticed that the rocker arms are pretty clanky during first start up and at general warm idle. I am thinking about adjusting my valves. I noticed there was some play in the rockers when I had the motor a TDC. I was wondering, the rockers slide on the shaft probably more than they should I'm sure they're pretty worn, will adjusting valves with worn rockers do more harm than good, or should I just be satisfied that it runs good (but chattery) now and leave them alone untill I decide to buy new? thanks.
It's hard to beat old trucks!!
Re: Adjusting Valves on 22re [Re: pdonahue] #843638 10/25/07 07:20 AM
kewlynx Offline
Valve Adjust
Screwdriver, 10mm wrench, angled feeler gauge(fits better than a straight one).
If doing it cold instead of warm, set them up with a heavy drag.
Make sure the rear half moon seal is still in place when you drop the cover back on! Makes a helluva mess if'n ya don't.
The valve adjustment screws are concave, and wear flat spots in them; easy enough to replace. Part number is listed in the part number sticky.
That should get you started; just look for signs of wear.
**ubi apis- ibi salus**
Re: Adjusting Valves on 22re [Re: kewlynx] #843639 10/25/07 02:18 PM
subliminaltrips Offline
its a 12mm wrench on the adjustors.
Re: Adjusting Valves on 22re [Re: subliminaltrips] #843640 10/26/07 01:21 AM
kewlynx Offline
Cool if it is; it's been awhile. Guess I've got clutch cylinder on the brain.
Re: Adjusting Valves on 22re [Re: kewlynx] #843641 10/26/07 05:07 AM
toyrunner Offline
12mm on the master and the slave as well <img src="/forums/images/graemlins/scared.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Adjusting Valves on 22re [Re: toyrunner] #843642 10/26/07 05:13 AM
kewlynx Offline
Lines on the master is a 10; just had to do one.
Re: Adjusting Valves on 22re [Re: kewlynx] #843643 10/26/07 07:34 AM
P
pdonahue Offline OP
Thanks guys. That should stop the chattering and perhaps make the engine a little more responsive? I'll do it on saturday. I already bought the straight feelers. damn it!
Re: Adjusting Valves on 22re [Re: pdonahue] #843644 10/26/07 07:49 AM
kewlynx Offline
If ya have the receipt, just exchange 'em. You can still do it with the straight set, but the angled ones make it so much easier to do.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6262 MB (Peak: 0.7044 MB) Data Comp: Off Server Time: 2026-11-03 13:36:19 UTC
