Revs high on start up #843680 10/26/07 12:40 AM
carook Offline OP
I have a 2002 Tracker 2.0 engine. With manual transmission. When I start car it seems to be reving faster than it should but does slow down pretty quickly. Any ideas?
Re: Revs high on start up [Re: carook] #843681 10/26/07 01:34 PM
maraguez Offline
They have an automatic accelerator so it accelerates when it is cold to warm up faster, is it really cold where you are? Maybe its just getting stuck a little bit. How high does it go? If over 5000 rpm's it could be a problem, if around 3500 there is no problem.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
Re: Revs high on start up [Re: maraguez] #843682 10/31/07 06:30 PM
carook Offline OP
I have had truck a couple months and has done it from the start. Temprature was in the 90's when first purchased. It might get to 3500 rpm at start but not 5000. Was kinda concerned with the fast start up with the cold weather coming. But does idle down pretty fast.
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5936 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-06-15 10:41:36 UTC
