2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires #843803 10/26/07 11:24 PM
bradford_johnson Offline OP
Hello all;
I need guidance on my set-up. IÆm thinking about adding a 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires on my rig. All else is still stock.
What pinion changes should I use to help ensure my road manners and mileage are not adversely effected. What components should I ensure are included in the lifts to keep the geometry in alignment (ie tire spacers, Pitman Arms, transmission lowering kits, etc)? I use this rig as a daily commuter, and rarely tackle anything harder than snow covered trails and dirt roads.
2004 TJ Wrangler Sport
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: bradford_johnson] #843804 10/27/07 08:07 AM
BobRowe Offline
For the type of driving you're proposing, I'd suggest ring and pinion sets of 4.10:1 for your axles.
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: BobRowe] #843805 10/28/07 05:37 PM
Brown81CJ5 Offline
Auto or stick? If stick then you may have to get an adjuster bracket of some sort 'cause a body lift can make the shifter bind.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: Brown81CJ5] #843806 10/28/07 10:16 PM
Sorry, a 5 speek manual. For me there is no other way to go.
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: Brown81CJ5] #843807 10/29/07 12:57 AM
DBL_DTY97TJ Offline
A 1" BL prolly won't causea shifter problem. You will eventually want to regear as BR said, but it doesn't have to be right now. The 2.5" lift most likely won't cause drivetrain angle problems, but I have heard of it happening - once. In which case a SYE and CV drive shaft will set you up. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: DBL_DTY97TJ] #843808 10/30/07 02:20 PM
Sorry, what is a SYE and CV drive shaft?
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: bradford_johnson] #843809 10/30/07 04:50 PM
Brown81CJ5 Offline
Slip Yoke Eliminator and Constant Velocity
Check this out.
web page
Gun it and run it!
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: Brown81CJ5] #843810 11/02/07 10:39 PM
Thank you all for your help. One last question, would it be easier to just go with a 3.5" lift? I was expecting a lot of geometry issues, but you all seem to discount them pretty quickly.
Re: 2.5ö suspension lift, a 1ö body lift, and 33 x 11ö tires [Re: bradford_johnson] #843811 11/02/07 11:38 PM
Brown81CJ5 Offline
You might possibly get a little driveline vibration, but the main thing you would need to worry about in getting a 3.5" lift is getting a dropped pitman arm. I personally would go with just the suspension lift.
Gun it and run it!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6266 MB (Peak: 0.7281 MB) Data Comp: Off Server Time: 2026-06-07 11:36:05 UTC
