Oil in overflow #843884 10/27/07 04:41 AM
drainsbe Offline OP
So.... I rebuilt the 22R-EB last year and have around 10K since then... new crank, rods, .030 over pistons, new EB RV head, cam, ARP studs, yada, yada... I checked my oil today and was a couple of quarts low, kinda wierd... got home, let it cool off and just started looking around under the hood... opened the rad cap.. nice and full. Opened the overflow bottle and was surprised to see nothing but black sludge... <img src="/forums/images/graemlins/scared.gif" alt="" /> easily a quart... no trace of water in the oil (that I can see), no milkshake under the oil cap, no white smoke, no gurgling sound from the heater. It runs great, doesn't overheat... What gives? Anyone ever heard of this b4?
I'm beyond frustration with this... I love this 4Runner, its been my dd for the last 3 yrs, but I've about had it... <img src="/forums/images/graemlins/angry.gif" alt="" /> gonna pull the spark plugs in the morning see if there is a story there... geez...
Dave
86 4Runner, 22R-EB
Re: Oil in overflow [Re: drainsbe] #843885 10/27/07 06:22 AM
Ganoid Offline
Did you by chance replace the timing cover or chain guides when you rebuilt? It may be worth your time to pull the T-stat and check for a hole in the timing cover underneath.
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: Oil in overflow [Re: Ganoid] #843886 10/27/07 08:23 AM
subliminaltrips Offline
sound like a hole in the timing cover or a bad gasket on the timing cover
Re: Oil in overflow [Re: drainsbe] #843887 10/27/07 09:10 AM
Bogo Offline
Sounds like your oil pressure is good. <img src="/forums/images/graemlins/smile.gif" alt="" /> I'd first suspect any gasket that has both coolant and pressurized oil routed through it. You could also have a corrosion hole between a high pressure oil line and a coolant area.
-- Bryan
Re: Oil in overflow [Re: Ganoid] #843888 10/27/07 02:31 PM
drainsbe Offline OP
Yes.... new timing cover, steel backed guides, tensioner, chain, oil pump, etc... dangit...
Dave
86 4Runner, 22R-EB
Re: Oil in overflow [Re: drainsbe] #843889 10/28/07 09:55 PM
engnbldr Offline
>>>*If the tensioner hung up enough to allow the chain to cut the cover it would be warning you with the classic rattling noise.
It is possible the gasket itself breached for some reason, there is a pressurized oil galley that runs pretty close and can leak oil into the coolant.
Typically that would be a chocolate milk color, though, not black. I would dump the coolant recovery bottle and wait, because if you have that much oil in there it should show in the crankcase on on the filler cap for sure.
Run her for awhile that way and see if it keeps coming, watch the oil level, too. Holler if you think you need a cover, 3 year warrenty on those....*EB
*Beats the he** outa me!....*LOL**...
Re: Oil in overflow [Re: engnbldr] #843890 10/29/07 12:38 PM
drainsbe Offline OP
Good advice... I'll change the oil this week too, that will let me know if there's any coolant in there fer sure <img src="/forums/images/graemlins/scared.gif" alt="" />
Run her for awhile that way and see if it keeps coming, watch the oil level, too. Holler if you think you need a cover, 3 year warranty on those....*EB
I'll let you know on the cover... not looking forward to tearing into it again. <img src="/forums/images/graemlins/shiner.gif" alt="" /> In Feb I had to replace the TC gasket because of an oil leak... <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" /> dangit
Thanx!
Dave
86 4Runner, 22R-EB
Re: Oil in overflow [Re: drainsbe] #843891 10/30/07 03:18 AM
kewlynx Offline
Little tip on inspecting that cover. If you have some kind of solvent laying around, pour a little into the cover and very slowly work it around. If there's any cracks not visible to the naked eye, the solvent will find it.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6254 MB (Peak: 0.7255 MB) Data Comp: Off Server Time: 2026-07-15 12:47:31 UTC
