tranny problems 95 rodeo #844028 10/28/07 04:50 AM
P
painter43213 Offline OP
read previous post from jeff mason on 8/23/07 and there was something that big swede sent him,something about a planet site with info on tranny limp mode fixes.can anyone tell me what that is?
Re: tranny problems 95 rodeo [Re: painter43213] #844029 10/28/07 05:57 AM
boritz Offline
Perhaps you are referring to BigSwede on http://forum.planetisuzoo.com?
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
Re: tranny problems 95 rodeo [Re: painter43213] #844030 10/28/07 11:16 PM
trooperbc Offline
seems that most often the cause for limp mode is the computer sensing electrical/electronic problems and uses that mode to protect its internal electronics including computer. it often is the charging system not putting out enough, most often the alternator itself, though it can be as simple as the simple stuff: connections, wiring, battery, battery terminals, grounds. here's a link to a thread in the archives here that gives a bunch of info i discovered, mostly from the factory manual
http://www.4x4wire.com/forums/showf...&sb=5&o=&fpart=1
btw, it can be *simple* stupid. i once got the ol limp mode from flipping the dimmer switch back and forth killing time at a red light -- so don't do that either.
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5941 MB (Peak: 0.6468 MB) Data Comp: Off Server Time: 2026-06-07 03:52:18 UTC
