Any comments on this Class III Hitch
#844068
10/28/07 06:34 PM
I am in the market for a "Class III" hitch for my 1996 Xcab 4x4. Anyone have any comments regarding the purchase of this hitch from this web site "See link below", price, performance and cost etc.. Other recommendation also welcome. http://www.hitch-web.com/proDescrip.asp?ProductCode=324804&OID=8#Thanks Much In Advance Regards Ron
1996 Toyota Tacoma XCab 4x4 3.4L ARB Bullbar & Warn Winch Super Spring progressive leaf springs SuperBumper in rear 2" receiver Moderator Marks factory Bilstein shocks/Front Coils Albuquerque, NM
Re: Any comments on this Class III Hitch
[Re: rrolsbe]
#844069
10/29/07 12:05 AM
Looks like a good hitch -- probably stronger than OEM Toyota model, which has the side plates bolted to the cross tube instead of welded.
I believe you may be able to get the same Curt hitch for a few less $ on Ebay, depending on where you live (shipping cost...)
Good Luck.
[Re: Whizkidder]
#844070
10/29/07 05:06 PM
I have Curt on my 98 Cherokee. It's heavy and stout as can be. FYI mine didn't come with mounting hardware but I bought it "open box" item for $50.
[Re: rrolsbe]
#844071
10/31/07 02:59 PM
Thanks for the replies. I purchased from realtruck.com
This was a slightly better price than I found on EBAY and the realtruck site was easy navigate.
Curt Class 3 Hitch Ball Mount w/ Right Angle Design - Fits 2" x 2" Receivers (#CU-D-6RA) Black Powder Coat - Style 2 (HS:1" Drop:4" Rise:2" Length:10 1/4" GTW:6,000/TW600lbs)
1 $40.99 $40.99 Curt Class 3 Rear Receiver Hitch - 2" x 2" Receiver Black Powder Coat (#CU-13013) Toyota Tacoma (1995 - 2004) ALL (Note:Z) Curt Class 3 Rear Hitches 10% OFF Today Only Please Note: Due to size or shipping requirements, this item has an Additional Handling Fee of $7.95. 1 $167.35 $167.35 -$16.74 Sub Total: $191.60 Please Note: some items due to size or weight may require an additional oversize handling charge. Shipping Method 5-7 Day Ground Shipping: $16.07 Handling: $7.95 Tax (0%): $0.00 Web Promo Shopzilla 10% Order Discount on Performance Coupon Code: SJ921 Savings: -$19.16 Order Total: $196.46
Regards Ron
[Re: rrolsbe]
#844072
11/05/07 11:42 PM
Under 2 bills delivered for a class III is great.
If you don't mind post up some before and after pics. I'd like to see how the Tacoma recievers mount up.
[Re: Seattlegti]
#844073
11/20/07 02:02 PM
Found the same hitch delivered for $43 dollars less at etrailer.com. Realtruck issued a price match certificate for $48 for my next purchase, now to find something to purchase. Bottom line could have purchased the Curt hitch and 4" drop for $151 delivered from etrailer.com. The hitch installed easy and uses the same bolts as the bumper brackets, plus two additional bolts included which also bolt to the frame. Bolts directly to the frame, I think the frame would bend before the hitch. The hitch sets back even with the inside back edge of the bumper and below it about a half an inch. The receiver attach point on the hitch extends to about an half inch behind the rear edge of the bumper. Tucks up nicely!
If I get a chance I will post some after pictures.
Regards Ron
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6102 MB (Peak: 0.6807 MB) Data Comp: Off Server Time: 2026-06-07 08:34:19 UTCValid HTML 5 and Valid CSS
