Soft brake pedal #844157 10/29/07 01:26 PM
A
AE86GTS Offline OP
so i'm running low on fund and time!
could use some side input!
so pretty much i have to double pump to get the brakes get firm or close to locking!
so far I have added new lines old ones rusted away!
front pads
tryed to adjust the rear shoes!
or maybe its that odd brake valve at the rear that adjust with the ride that link to the axle?
hmmmmm....
and bleed the brakes all the way threw
so now i'm wondering if its the master cyl going or the brake booster
or maybe new shoes or drums in the rear that did adjust a bit!
let me know what you think!
__________________
Re: Soft brake pedal [Re: AE86GTS] #844158 10/29/07 02:16 PM
OOP'S Offline
This is the proper way to bleed your brakes to avoid spongy brakes, etc...
"...This is from the FSM and it works great..."
1. Drivers side rear
2. Passenger side rear
3. Passenger side front
4. Drivers side front
5. LSPV (Load sensing proportioning valve)This is the odd looking valve.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Soft brake pedal [Re: OOP'S] #844159 10/29/07 04:37 PM
L
ldrdl Offline
take your drums off and check your wheel cylanders. i had the same problems and replaced everything(except the lines/and booster) when all that was wrong the whole time was 1 leaky wheel cylander.
Re: Soft brake pedal [Re: ldrdl] #844160 10/29/07 07:02 PM
A
AE86GTS Offline OP
was the load sensing proportioning valve at the rear <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Soft brake pedal [Re: AE86GTS] #844161 10/30/07 12:28 AM
OOP'S Offline
Yes, it is on the frame above the rear axle on the PS. It has a rod conncted to the rear end housing on the DS.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6046 MB (Peak: 0.6691 MB) Data Comp: Off Server Time: 2026-06-17 10:39:54 UTC
