Soft brake pedal
#844157
10/29/07 01:26 PM
so i'm running low on fund and time!
could use some side input!
so pretty much i have to double pump to get the brakes get firm or close to locking!
so far I have added new lines old ones rusted away! front pads tryed to adjust the rear shoes! or maybe its that odd brake valve at the rear that adjust with the ride that link to the axle?
hmmmmm.... and bleed the brakes all the way threw
so now i'm wondering if its the master cyl going or the brake booster or maybe new shoes or drums in the rear that did adjust a bit!
let me know what you think!
__________________
Re: Soft brake pedal
[Re: AE86GTS]
#844158
10/29/07 02:16 PM
This is the proper way to bleed your brakes to avoid spongy brakes, etc...
---------------------------------------------------- "...This is from the FSM and it works great..." 1. Drivers side rear 2. Passenger side rear 3. Passenger side front 4. Drivers side front 5. LSPV (Load sensing proportioning valve)This is the odd looking valve.
"Serenity through Sobriety"
[Re: OOP'S]
#844159
10/29/07 04:37 PM
take your drums off and check your wheel cylanders. i had the same problems and replaced everything(except the lines/and booster) when all that was wrong the whole time was 1 leaky wheel cylander.
[Re: ldrdl]
#844160
10/29/07 07:02 PM
was the load sensing proportioning valve at the rear <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: AE86GTS]
#844161
10/30/07 12:28 AM
was the load sensing proportioning valve at the rear <img src="/forums/images/graemlins/cheers.gif" alt="" /> Yes, it is on the frame above the rear axle on the PS. It has a rod conncted to the rear end housing on the DS.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6046 MB (Peak: 0.6691 MB) Data Comp: Off Server Time: 2026-11-03 11:40:34 UTCValid HTML 5 and Valid CSS
