Intermittent Wiper Control Module? #844177 10/29/07 03:54 PM
captdave311 Offline OP
I fried whatever it is that controls the intermittent speed on my windshield wipers...
The cause: heavy snow preventing movement of the wiper arms, despite this, I left the wipers on.
The symptoms: Turn wiper control to intermittent and the wipers move back and forth like they were on the slow setting, turn wipers to slow and they behave normally and turn wipers to fast and the behave normally.
The question: I've been told there's an intermittent wiper control module (and the Haynes manual's only reference to the module is in a wiring diagram) somewhere in the car, however, I'm at a loss as to where to look! I am about to replace the entire wiper control switch (it looks like there's some circuitry in that assembly that could get messed up), but I'm not entirely sure if this is the right step. Can anyone out here tell me if I'm doing the right thing? Also, I'm curious to know if anyone can either describe to me the appearance (or even better, a picture) of the intermittent wiper control module?
Thanks in advance.
Dave
1998 Cherokee Sport/4.0 L H.O./5 speed manual
Bitchin' stereo/modified seat to fit my long legs
Considering off-roading acessories before vehicle upgrages
Re: Intermittent Wiper Control Module? [Re: captdave311] #844178 11/01/07 09:55 AM
8
82shortbox Offline
Just went through a problem with my wipers on my 88 Wrangler, they quit working totally. The module on mine is to the left of the steering column, if you trace the wiring harnass out of the bottom of the steering column they plug into a 2x4 module and then continue up to the main harnass. I lucked out in that mine ended up being caused by a mouse nest I found above the steering column. Mouse piss must be corosive! Cleaned it up and now even my washer works. My jeep sat in a horse barn for 4 years before I bought it, still smells like hay when it gets wet. Gordie
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5891 MB (Peak: 0.6375 MB) Data Comp: Off Server Time: 2026-06-07 06:54:56 UTC
