can't find driveshaft #844404 10/31/07 12:26 AM
I
irsean Offline OP
Having trouble finding replacement driveshaft.
Bearings are all going out but there is a small dent in the shaft. Should I replace the whole shaft (2wd 5 spd) or just the bearings?
BTW: Found a used one nearby but, yard wants too much (>$250).
Re: can't find driveshaft [Re: irsean] #844405 10/31/07 12:35 AM
Staceman Offline
Short bed, or long bed?
what year?
Re: can't find driveshaft [Re: Staceman] #844406 10/31/07 12:39 AM
OOP'S Offline
Have it re-tubed.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: can't find driveshaft [Re: Staceman] #844407 10/31/07 12:40 AM
Vanishing_Point Offline
I have two for cheap. One out of an '84 2wd and one from an '86 2wd. They are from 4 spds. I can measure to confirm lengths.
Re: can't find driveshaft [Re: Staceman] #844408 10/31/07 12:41 AM
Staceman Offline
Check car-part.com
Here's an example of a 1988 SWB, 5Sp. rear 2WD driveshaft.
(shipping may run $20-$30 extra, gotta call 'em to find out)
Rear Drive Shaft
Toyota Truck 2.4L,5 Sp,RWD A BD0374 $45 A & G Auto Recycling USA-OR(Creswell) E-mail 1-866-643-2714
1988
Rear Drive Shaft
Toyota Truck 2.4L,MT,RWD CJ1263 $45 A & G Auto Recycling USA-OR(Creswell) E-mail 1-866-643-2714
Re: can't find driveshaft [Re: Staceman] #844409 10/31/07 02:58 AM
4Crawler Offline
You might try a local drive shaft shop. They may be able to work the dent out, or re-tube the shaft as noted above. They can also replace the u-joint bearings or supply the parts to do so.
Re: can't find driveshaft [Re: irsean] #844410 10/31/07 06:20 PM
I
irsean Offline OP
Sorry, the specs are:
1984 2WD 5spd Manual X-tra Cab 22-R
Needs shaft and bearings
Re: can't find driveshaft [Re: irsean] #844411 10/31/07 07:13 PM
Staceman Offline
Rear Drive Shaft
Toyota Truck A 8TY444 $25 Oakleaf Auto, Inc. USA-SD(Hartford) E-mail 1-800-952-0038
1987
Rear Drive Shaft
Toyota Truck A 8TY750 $25 Oakleaf Auto, Inc. USA-SD(Hartford) E-mail 1-800-952-0038
1989
Rear Drive Shaft
Toyota Truck TWO PIECE A 990195 $25 A-1 Auto Salvage USA-AR(West-Memphis) E-mail 1-800-240-3795
It's up to you to decide now.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6243 MB (Peak: 0.7067 MB) Data Comp: Off Server Time: 2026-05-29 15:25:38 UTC
