can't find driveshaft
#844404
10/31/07 12:26 AM
Having trouble finding replacement driveshaft. Bearings are all going out but there is a small dent in the shaft. Should I replace the whole shaft (2wd 5 spd) or just the bearings? BTW: Found a used one nearby but, yard wants too much (>$250).
Re: can't find driveshaft
[Re: irsean]
#844405
10/31/07 12:35 AM
Short bed, or long bed?
what year?
[Re: Staceman]
#844406
10/31/07 12:39 AM
"Serenity through Sobriety"
[Re: Staceman]
#844407
10/31/07 12:40 AM
I have two for cheap. One out of an '84 2wd and one from an '86 2wd. They are from 4 spds. I can measure to confirm lengths.
[Re: Staceman]
#844408
10/31/07 12:41 AM
Check car-part.com Here's an example of a 1988 SWB, 5Sp. rear 2WD driveshaft. (shipping may run $20-$30 extra, gotta call 'em to find out) 1989 Rear Drive Shaft Toyota Truck 2.4L,5 Sp,RWD A BD0374 $45 A & G Auto Recycling USA-OR(Creswell) E-mail 1-866-643-2714 1988 Rear Drive Shaft Toyota Truck 2.4L,MT,RWD CJ1263 $45 A & G Auto Recycling USA-OR(Creswell) E-mail 1-866-643-2714
[Re: Staceman]
#844409
10/31/07 02:58 AM
You might try a local drive shaft shop. They may be able to work the dent out, or re-tube the shaft as noted above. They can also replace the u-joint bearings or supply the parts to do so.
[Re: irsean]
#844410
10/31/07 06:20 PM
Sorry, the specs are: 1984 2WD 5spd Manual X-tra Cab 22-R Needs shaft and bearings
[Re: irsean]
#844411
10/31/07 07:13 PM
1984 Rear Drive Shaft Toyota Truck A 8TY444 $25 Oakleaf Auto, Inc. USA-SD(Hartford) E-mail 1-800-952-0038 1987 Rear Drive Shaft Toyota Truck A 8TY750 $25 Oakleaf Auto, Inc. USA-SD(Hartford) E-mail 1-800-952-0038 1989 Rear Drive Shaft Toyota Truck TWO PIECE A 990195 $25 A-1 Auto Salvage USA-AR(West-Memphis) E-mail 1-800-240-3795 It's up to you to decide now. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
