mod-ed 22re(93-4x4pu) #844436 10/31/07 02:26 AM
toyneedshelp Offline OP
Ive got a 93 toy-p/u...I put a mod-ed Kieth Black 22re motor in it built by johns foreign engines..view the extras @ 22re.com..Along with it I put a Pace Setter header,high flow cat,and muffler on...Also from same site....My truck seems to be running a lil off...Any help.....Seems to be running rich???272 delta reground cam and header make a mapin issue????MAF sensor adjust???Im confused?????Any help out there?????
Re: mod-ed 22re(93-4x4pu) [Re: toyneedshelp] #844437 11/02/07 01:16 AM
sanuoff Offline
how rich, black smoke all the time?
what kinda fuel milage you getting?
Re: mod-ed 22re(93-4x4pu) [Re: toyneedshelp] #844438 11/02/07 01:26 AM
kewlynx Offline
JFE is a crook. <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Make sure your TPS is set up properly.
**ubi apis- ibi salus**
Re: mod-ed 22re(93-4x4pu) [Re: kewlynx] #844439 11/02/07 01:35 AM
CJM Offline
talk to the builder !!! ya just got it .
83 Trekker SR5
NEW Trekker forum
Re: mod-ed 22re(93-4x4pu) [Re: toyneedshelp] #844440 11/02/07 05:46 AM
rexburg22re Offline
I just finished rebuilding my motor 92 4x4 pu 22re.
Pace Setter header, high flow cat, and muffler on also from same site. My truck seems to be running a lil off. Any help. Seems to be running rich? 272 delta reground cam and header make a mapin issue? MAF sensor adjust? Im confused? Any help out there?
edited your post so I could make sense of it...
what are the "extras"? i'm too lazy to go look.
what i did to mine;
-bore .020 over
-port/polish intake
-backflush/balance injectors
-cold air intake
-downey broad range cam
-downey header to 2 1/2 inch exh, no cat, flowmaster muff.
-jet reprogrammed ECU.
-had to have throttle position sensor re-calibrated
-had to adjust valves for new cam and again after break-in(and again because i adjusted them cold using hot specs.)
-need to advance cam 2* ahead
i would recommend
-making sure cam timing is where it should be
-valves are adjusted to new cam setting (probably warm setting but check to make sure)
-have your TPS checked.
-have your MAF checked.
Did you have your ECU reprogrammed? Was it done right? Jet messes up on like 5% or so i've heard. I'm not sure mine is right yet... i'll know after i advance my cam.
Did you drop the motor in yourself, with friends, have a shop do it?
that should be enough to start with...
Re: mod-ed 22re(93-4x4pu) [Re: rexburg22re] #844441 11/02/07 09:23 PM
G
Greg_Canada Offline
Your jet program is probably doing nothing at all. it's a waste of money.
to get true tuning, you have to use a box like an SMT-6.
89 4Runner
Re: mod-ed 22re(93-4x4pu) [Re: sanuoff] #844442 11/03/07 12:30 AM
not visable...plugs look ok??? pulled header off,got black flake and soot after like 1200 miles...getten like 14mpg..31x10.5x15 Dick Cepek mudders....
Re: mod-ed 22re(93-4x4pu) [Re: kewlynx] #844443 11/03/07 12:32 AM
really???tps do-able myself???took it to the dealer,mistake...they did a cumbustion chamber flush,after i told them it was a new motor...TARDS!!!
Re: mod-ed 22re(93-4x4pu) [Re: CJM] #844444 11/03/07 12:35 AM
the shaft???theyre playin dumb...i took the truck there twice and theyre like"dono what to tell ya man"LAME!!!
Re: mod-ed 22re(93-4x4pu) [Re: rexburg22re] #844445 11/03/07 12:37 AM
the motor comes in a long block built by them in lacenter washington...its the 2350$ one...i feel let down...just tryin to get it runnin rite...
PHP: 7.4.33 Page Time: 0.029s Queries: 16 (0.024s) Memory: 0.6381 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-11-04 20:01:13 UTC
