Steering box play
#844505
10/31/07 02:19 PM
I have an 88 Ram 50, case you couldn't tell by my username and dozens of other posts. <img src="/forums/images/graemlins/lol.gif" alt="" />
Is the steering box play adjustable on these? I seem to have a wandering problem and alot of play in the wheel.
Re: Steering box play
[Re: 88D50]
#844506
10/31/07 03:39 PM
yes they are adjustable but have you looked at your idler arm and other steering first?
[Re: powerRam50]
#844507
11/02/07 12:44 AM
All new tie rods, and the shop said my idler and pitman arm are in good shape.
[Re: 88D50]
#844508
11/02/07 12:48 AM
they just have a lot of play...I have never seen a ram 50 that didn't have quite a bit...my old truck had a slight pull to the right so that made it easy to drive...no wandering at all hahah.
[Re: 88D50]
#844509
11/02/07 03:41 AM
when you adjust the freeplay make sure you go a little at a time and do several test drives.you dont want to tighten it up to much
[Re: torquemonster]
#844510
11/02/07 09:26 PM
my old truck had a slight pull to the right so that made it easy to drive...no wandering at all hahah. I know what you mean. I had a pull untill I had it aligned. Now it wanders. *sigh*
