Headlight Conversion #844511 10/31/07 02:31 PM
8
87BBdriver Offline OP
Just curious on everyone's thoughts of this conversion kit from auto parts warehouse....
web page
It would be the 2nd one down with the 7" round...Any thoughts?
Re: Headlight Conversion [Re: 87BBdriver] #844512 10/31/07 11:42 PM
87Raider_TSI Offline
If you are going to go with a conversion lense, go with the Hella.
Hella's on Amazon
Or if you really want the best, look for the European Hella lenses. I have them on my truck and they are great.
'87 Raider SWB 2.6T/5 spd - Boxy and boosted.
'88 Conquest TSI - MPI and lots of other mods
Re: Headlight Conversion [Re: 87Raider_TSI] #844513 11/01/07 01:08 AM
PHIL_ Offline
+1 on Hella H4 E-codes. Awesome!!!
Re: Headlight Conversion [Re: PHIL_] #844514 11/01/07 02:16 AM
CapnCrunch Offline
Way cheaper.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Headlight Conversion [Re: CapnCrunch] #844515 11/01/07 03:13 AM
8
Thanks for the info on the Hella's. Is this a pretty standard swap? Pull the old light, and hook up the new, or will I have to do any rewiring?
Re: Headlight Conversion [Re: 87BBdriver] #844516 11/01/07 04:42 AM
89montero Offline
when my gen1 lights burnt out I replaced them with delta tech xenon's, they were about 70 bucks from quadratech and work great. Really sharp cut offs and they're really bright. They are white with a hint of blue. I think they are European E-code lenses
http://www.deltalights.com/products.asp?pid=23704
part number 01-1149-50X
it says it's for jeep but it's still just a 7" round headlight, fit fine in my montero. I think I might have had to bend one of the tabs a little with some pliers to get it to fit snug.
1989 Montero 4dr V6 3.0l
Re: Headlight Conversion [Re: 87BBdriver] #844517 11/01/07 06:02 AM
ryany Offline
The headlights should be drop-in replacements with no rewiring necessary. However, if your original wiring is worn or has really brittle insulation, you should think about replacing it. Most factory headlamp wiring is barely adequate for the stock lamps, and is usually undersized for any higher wattage bulbs. If you stick with the stock wattage bulb (usually 55/60 watt), you shouldn't have any problems.
95 Montero SR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6196 MB (Peak: 0.6936 MB) Data Comp: Off Server Time: 2026-06-07 10:35:43 UTC
