4x4 Raider Queshion! #844552 11/01/07 02:16 AM
Dieselburns Offline OP
Hello Gang! Its been about three months since Ive purchased the raider and today I decided to see how the 4 wheel drive works. My question is when I shift from 2wd to 4wd high I see the wheel lock light appear, as wheel as the 4wd double axle light. I here it working well, and the feel of the steering feels more stronger. Though when I shift from 4wd high to 2wd I see the 4wd double axle light disappear, but the wheel lock light still appears, even while driving. When I got home I shut off the truck an return the key to see that the wheel lock light is still on. Is this normal, and how can I turn off the wheel locks? I do have the stock auto hubs.
BTW: what is the correct way to change from 4wd high to low?
Thanks,
1989 Dodge Raider V6 5speed Red/Gray
1978 Mercedes 300D Diesel
1978 Mercedes 240D Diesel
Re: 4x4 Raider Queshion! [Re: Dieselburns] #844553 11/01/07 02:55 AM
powerRam50 Offline
when you shift to 2wd you have to back up for a few feet.
Re: 4x4 Raider Queshion! [Re: powerRam50] #844554 11/01/07 02:57 AM
To disengage the wheel locks...Right?
Re: 4x4 Raider Queshion! [Re: Dieselburns] #844555 11/01/07 03:18 AM
sparkem Offline
Yes.
Re: 4x4 Raider Queshion! [Re: sparkem] #844556 11/01/07 03:57 AM
StockRaider Offline
Easiest thing to do is read the drivers door panel. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 4x4 Raider Queshion! [Re: StockRaider] #844557 11/01/07 04:08 AM
Oh stupid me I totally forgot that. Thanks! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 4x4 Raider Question! [Re: Dieselburns] #844558 11/01/07 04:37 AM
89montero Offline
to shift from 4high to 4low and visa versa you have to come to a complete stop and put the tranny in neutral.
When you first put it in 4high you must be completely stopped but after that as long as the "wheel lock" light is on you can shift between 2wd and 4high while driving at any speed, just move the shifter.
1989 Montero 4dr V6 3.0l
Re: 4x4 Raider Queshion! [Re: Dieselburns] #844559 11/01/07 04:48 AM
CapnCrunch Offline
Come to a complete stop before shifting from HI to LO and vice versa.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 4x4 Raider Question! [Re: 89montero] #844560 11/01/07 04:49 AM
StockRaider Offline
Not true. My sensor went bad in my Raider in the winter. I went from 4wdhi to 2wd and was going down the road, hit a snowy patch. Engaged 4wd and one of the hubs wasnt engaged anymore. GRRRRRRRSSSSSSHHHHH.... That hub never did lock right after that. <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6292 MB (Peak: 0.7318 MB) Data Comp: Off Server Time: 2026-06-23 04:50:51 UTC
