Possible to make torsion bars quiet? Can't sneak in woods!
#844665
11/01/07 01:50 PM
Hey fellas,
Deer hunting season is in full swing here in TN. With my GEN 1 there is no way for me to sneak into the woods. My Torsion bars creak so loud I might as well be playing rap music over a pa system as far as the deer are concerned.
Is there anything I can do?
Thanks!
--Tres (John 14:6)
Black 87' Raider 2.6L/Webber 88 5 Speed Welded front,tight LSD in the rear Removed bump stops 4'x6' roof rack 10k. Lb. winch on receiver hitch/custom bumper 100 amp alt CB radio/AC inverter S.Winch hubs Enormous RV battery
Re: Possible to make torsion bars quiet? Can't sneak in woods!
[Re: TresMon]
#844666
11/01/07 02:28 PM
It may not be the bars, per se, but rather the lower front mounting points, a.k.a. the lower a-arm pivot points. Mine would squeal like crazy. There are no grease fittings there, so I just douse both ends of the a-arm with WD-40 and they're quiet for a week or so. Hope that helps.
[Re: JohnnyBfromPeoria]
#844667
11/01/07 04:56 PM
I'll soak it with the WD and see what happens.
Thanks.
--Tres (John 14:6)
[Re: TresMon]
#844668
11/01/07 09:01 PM
I'd get out walk... but that's just me, I don't roadhunt. <img src="/forums/images/graemlins/notooth.gif" alt="" />
As for the bars, if you can white lithium grease in there, it will last longer than others.
-Dave D Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..." -Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
[Re: ForcedAir_Montero]
#844669
11/01/07 09:52 PM
I tried spray lithium grease, but it wouldn't get in to where it made a difference. Sometimes I'd WD-40 it first, then add a layer of the grease to help hold it in there, too. As I recall, that did about the same thing as just the WD-40 by itself.
#844670
11/02/07 11:15 PM
yep them deers ull come a runnin to that wd40... spray some on yer shoes too
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
[Re: generation_one]
#844671
11/08/07 01:38 PM
How about WD on yer boots and doe pee on the bars <img src="/forums/images/graemlins/smile.gif" alt="" />
1990 MonTERROR 183.07 cubic inches of worn out FURY New ALTINATOR And uh... new radiator hoses UPPER AND LOWER, SAGGING COILS, dead SHOCKS Worn 29 x something x something else STREET TIRES GET SOME
[Re: TresMon]
#844672
11/08/07 10:50 PM
Mine has bearing grease packed into both splines front and rear. Never squeaks.
