heater control switch #844798 11/02/07 05:20 PM
Brice Offline OP
Howdy ya'll
New to this forum and hopefully you can help me.
I have a 1990 toyata 22re 4x4 automatic hunting truck.
My problem is only the 2 highest settings on the heater control switch works, its either burning up or freezing.
How and what do i fix ? Also where do i fix it ? lol <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: heater control switch [Re: Brice] #844799 11/02/07 05:32 PM
4Crawler Offline
Could be a burned out resistor:
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml#BlowerResistor
Although that usually only affects all but the highest speed. But it is easy to check.
Re: heater control switch [Re: 4Crawler] #844800 11/02/07 05:47 PM
Brice Offline OP
Thanks for the info, I will get on it and hopefully figure it out. I will let you know later. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: heater control switch [Re: 4Crawler] #844801 11/02/07 08:30 PM
Brice Offline OP
Found the resistor, took it out and it is a 3 pring resistor
with 1 broken. hopefully that is all i need to fix.
Keep u updated after the new one comes in.
Re: heater control switch [Re: Brice] #844802 11/02/07 09:59 PM
Staceman Offline
That'll fix you up just fine Brice.
4Crawlers site is a WEALTH of info.
I even have print-outs from that site, stuffed along the inside of the FSM. Knowledge is power my friend.
Re: heater control switch [Re: Staceman] #844803 11/07/07 06:08 PM
Brice Offline OP
Thanks for the info !
I will check that site out too.
Re: heater control switch [Re: Brice] #844804 11/07/07 06:10 PM
Brice Offline OP
BTW, the new resistor is installed and working great.
No i can actually be comfortable driving it around. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: heater control switch [Re: Staceman] #844805 11/07/07 06:22 PM
Brice Offline OP
4Crawlers
Is that 4crawlers.com ???
Or is it called something close to that ?
Re: heater control switch [Re: Brice] #844806 11/07/07 09:49 PM
Staceman Offline
www.4crawler.com <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6247 MB (Peak: 0.7109 MB) Data Comp: Off Server Time: 2026-06-23 13:08:25 UTC
