ADD 4wd problems
#844846
11/02/07 07:43 PM
I have a 95 t100 and just noticed that 4wd will not engage(worked fine last sping). I located the vacuum lines on the acuator and firewall and they same to be intact with no cracks.
Here is the strange thing, while trouble shooting I reversed the lines on the acuator and then 4wd engaged as soon as I shifted into 4wd?
My first thought was a bad line so I switched them back to std on the actuator and reversed them at the electric switches, same thing instant on?
89 ext cab 22re 4x4 267K miles (for sale) 94 Land Cruiser Factory lockers 95 T100 4x4 ext cab
Re: ADD 4wd problems
[Re: CMH]
#844847
11/03/07 01:48 AM
Seems like if you don't put it into 4wd for a while either the switch, the relays, or something else does not always make contact. When you put in in the second time it either freed up or the corrosion was rubbed off the contact. Mine was doing the same thing and now I try to shift it in at least 1x a month and no problems since.
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
[Re: CMH]
#844848
11/04/07 12:21 AM
follow factory recommendations. Run the 4wd every month for a few miles. Run the low as well
trafdlo
[Re: CMH]
#844849
11/04/07 03:18 AM
Thanks...but mine still dos not work unless I swap the vac lines.
My guess is that when I swap lines it leaves the add system engaged (kind of like leaving the hubs locked in a non add truck). Technicaly 2wd till I shift to 4wd but the axles and diff are spinning.
To troubleshoot the system I need to know what ports should have vac applied in 2wd and in 4wd.
[Re: CMH]
#844850
11/04/07 08:14 PM
I have the pdf files for my 93T from the factory service manual. Can find everything for the tranny ops except for vacuum systems. Perhaps someone out there can help on where to look. Spent about 30 minutes looking through stuff and it must be hidden. Do not see anything in my Haynes manual either.
trafdlo
[Re: wsquaredodie]
#844851
11/04/07 09:59 PM
In the FSM... I think the ADD vac stuff is in the suspension/axle chapter. At least for my 97.
97 T100 4x4 97 328i 95 540i restoration project
[Re: eleet]
#844852
11/05/07 04:15 AM
nope, not there in mine. Anyoune out there with an idea?
trafdlo
[Re: CMH]
#844853
11/05/07 04:33 AM
I misread you post as saying that after you switched hoses and switched back all was OK. PMd you with some testing info. Hope it helps.
[Re: garym]
#844854
11/06/07 01:36 AM
[Re: CMH]
#844855
11/08/07 07:03 AM
Thanks for PDF file, turns out the solenoid that applies vac for engagement is not opening all the way, $400 for a new one from toyota
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6363 MB (Peak: 0.7429 MB) Data Comp: Off Server Time: 2026-06-07 04:25:21 UTCValid HTML 5 and Valid CSS
