22r leakdown test #844996 11/03/07 05:04 AM
saylracer Offline OP
just performed a compression test and leak down test on my new to me 84 4x4. The numbers are as follows
compression- #1-150psi...#2,3,4-170psi
leakdown- #1-65%.....#2,3,4-35%
Durung leakdown test cylinder #1 was leaking through exhaust and out through the valve cover(PCV hole)
Cylinders 2,3,4 were mostly leaking through valve cover( PCV hole)
Sounds to me like leakage could be caused by bad valves and valve guides. Am I right in this?
Re: 22r leakdown test [Re: saylracer] #844997 11/03/07 02:10 PM
avtech Offline
Yep,
Sounds like valve's, valve seats, valve guides etc....
Re: 22r leakdown test [Re: avtech] #844998 11/04/07 04:56 PM
Vanishing_Point Offline
A head job is in order.
Re: 22r leakdown test [Re: Vanishing_Point] #844999 11/04/07 11:26 PM
something I forgor to mention....when performing the compression test in cylinder #1 the original reading was 150psi. I then inject some oil into the cylinder and re-checked. The new reading was 8-10 psi higher (158-160)Being that all the other cylinders had good compression could the #1 have stuck rings or does this signal some other damage.
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6002 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-11-04 20:00:12 UTC
