busted leaf springs #845255 11/04/07 04:03 PM
myfrstrodeo Offline OP
94 rodeo has a busted leaf on both passenger and driver side. is it worth trying to replace them my self or should i bring it somewhere.
also, is it that big of a deal to replace the fuel pump myself? the tank itself looks like it would come out without to much of a fight.
Re: busted leaf springs [Re: myfrstrodeo] #845256 11/04/07 05:12 PM
strawmyers Offline
Isuzu Moderator
All it takes is a basic set of metric wrenches/sockets. I believe 14mm, 17mm, 19mm, and 24mm will cover it... maybe a 10 or 12 for the e-brake cable bracket bolt. Start spraying everything with PB Blaster now and repeat daily until you do the project. If you can turn a bolt, you can replace leaf springs.
The fuel pump is pretty basic as well. Unbolt skid plate, unbolt tank supported by floor jack, lower a bit and then disconnect hoses/electrical connections, lower the rest of the way, unbolt pump, replace, repeat above steps in reverse order.
Sean Strawmyer
Re: busted leaf springs [Re: strawmyers] #845257 11/04/07 11:04 PM
lttlbddy Offline
Lowering the gas tanks works best if it is low on fuel <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: busted leaf springs [Re: lttlbddy] #845258 11/05/07 04:28 AM
Jim_Paget Offline
Actually, lowering it is a lot easier if it is full. However, lowering UNDER CONTROL and without hurting yourself is best done with the tank as close to empty as possible. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: busted leaf springs [Re: myfrstrodeo] #845259 11/06/07 02:38 AM
thanx for the tips. that makes me feel better about everything. after replacing the alternator in my 98 chevy s10 2.2, thats lowered 2in.i know lowered trucks are not your guys style but i did it with out removing anything out of the way.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6054 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-20 20:27:42 UTC
