Trail Gear Ring and Pinion #845266 11/04/07 04:54 PM
Vanishing_Point Offline OP
Anybody had experience with the trail gear ring and pinion? I was wondering what the quality was like.
Re: Trail Gear Ring and Pinion [Re: Vanishing_Point] #845267 11/04/07 05:55 PM
OOP'S Offline
One of the best Gear men I know has endorsed them. That would be good enough for me if I bought stuff from T-G.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Trail Gear Ring and Pinion [Re: OOP'S] #845268 11/05/07 03:04 AM
Anybody know if they are loud or quiet running?
Re: Trail Gear Ring and Pinion [Re: Vanishing_Point] #845269 11/05/07 03:08 AM
kewlynx Offline
If they're loud, you haven't set them up right.
**ubi apis- ibi salus**
Re: Trail Gear Ring and Pinion [Re: kewlynx] #845270 11/05/07 03:38 AM
OOP'S Offline
Set-up is the key to any gear install.
David Fritzsche
Roseville, CA
Re: Trail Gear Ring and Pinion [Re: OOP'S] #845271 11/05/07 06:55 AM
I don't mean loud per say, I've heard that poor gear sets "new" will actually produce sound.
Re: Trail Gear Ring and Pinion [Re: Vanishing_Point] #845272 11/05/07 07:07 AM
kewlynx Offline
Some of these FAQs might help. This site has a pretty good tech section.
http://www.ringpinion.com/FAQ.aspx#37
Re: Trail Gear Ring and Pinion [Re: kewlynx] #845273 11/05/07 10:44 PM
Ganoid Offline
I have put in 4 or 5 sets and sold them on craigs list. I have never had any calls on them failing and I run a set in my front 8" and rear V6 diffs currently with no problems. I do like the V6 set better than the 4cyl set due mainly to the finish. The 4 cyl sets have a hard shiny finish where the V6 sets have a black oxide finish that made gear patterns much easier to read. You could tell the V6 set had a higher quality feel to them and the pattern looked fantastic. For what its worth the V6 set had a Yukon part number on it. This is a V6 setup I sold on CL I didn't take any pics of the 4cyl set's... not really sure why??
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: Trail Gear Ring and Pinion [Re: Ganoid] #845274 11/06/07 01:39 AM
OOP'S Offline
That is funny, a certain employee at TG has said their gears are made especally for TG!!!!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
David Fritzsche
Roseville, CA
Re: Trail Gear Ring and Pinion [Re: OOP'S] #845275 11/06/07 02:26 AM
subliminaltrips Offline
yea i have had excellent luck with my tg 5.29's i tore one down i set up that was open and dropped in an aussie locker, i had broken 2 birfs and hammered on it quite a bit and it showed no wear signs but the shiny gears were a bit of a pain to check the patern as said above. and for the record they are made by yukon, i had them side by side with a spare yukon r&p set i have and the part #s were nearly identical. if you doubt their strength send them to bobby to have them cryoed.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6377 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-05-29 18:58:24 UTC
