cant find prob with 02 sensors HELP!!!!!!!!! #845341 11/04/07 07:48 PM
bobcamp Offline OP
pulled codes p0135 an p0141.....changed sensors now have p0134 an p0140 also... have been checking wires but cant find anything wrong except 4 shielded gray cables spliced....is this the problem or should I look elsewhere..?????
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: bobcamp] #845342 11/05/07 05:31 AM
bombardj1 Offline
I tried to reply earlier guess it did not post, both 0134 and 0140 are not activity, did you splice the sensors in ? some aftermarkets don't work well. John
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: bombardj1] #845343 11/05/07 09:49 AM
bobcamp Offline OP
I used bosch oem sensors...tried splices then went with plug ins ....
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: bobcamp] #845344 11/05/07 01:01 PM
Axe Man Offline
Kia Moderator Emeritus
That's your problem. The universal Bosch O2 sensors have to be custom wired. You can't just plug them in.
On the engine wiring harness side here is the correct color code and function. Match that up to the color code and function provided with the sensors:
Front O2 sensor:
Yellow/white - O2 +
Blue - O2 - (ground)
Lt green/red - Either heater wire
Red/green - Either heater wire
Rear O2 sensor:
Blue - O2 +
Yellow/white - O2 - (ground)
Green/blue - Either heater wire
Black/red - Either heater wire
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: Axe Man] #845345 11/07/07 11:36 AM
bobcamp Offline OP
Thanks axeman....checked front sensor ok. When I checked back it was wired wrong. pulled out pins on sensor an changed positions cleared codes will let you know if it worked......Bob
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: bobcamp] #845346 11/08/07 01:41 AM
bumpcity76 Offline
I'm having the same issue with my 2001 2wd 2-door. I replaced both O2 sensors with Denso universals. With my OBD tool, I see activity on both sensors. I just can't get rid of p0135 & p0141!!!
<img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: bumpcity76] #845347 11/10/07 04:43 PM
Axe Man Offline
P0135 - Front O2 sensor heater malfunction.
P0141 - Rear O2 sensor heater malfunction.
Check both O2 sensor heater fuses. You might have blown them when you initially wired the sensors incorrectly.
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: Axe Man] #845348 11/10/07 08:14 PM
bumpcity76 Offline
I don't think I wored mine wrong. They both work. I only found one of the blocky 30A fuses blown, but replaced it. Still have codes. I don't even know what the blown fuse was for.
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: bumpcity76] #845349 11/10/07 08:40 PM
Axe Man Offline
In the fuse box in the passenger compartment, lower right. There are two 10 AMP fuses for the O2 sensor heaters. Check them.
Re: cant find prob with 02 sensors HELP!!!!!!!!! [Re: Axe Man] #845350 11/11/07 01:15 AM
bobcamp Offline OP
axe changed wires heater went off codes came up 134reset then131then heater codes kicked back on
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6318 MB (Peak: 0.7551 MB) Data Comp: Off Server Time: 2026-06-21 17:17:05 UTC
