Locking up the front end #845553 11/05/07 08:59 PM
redraider Offline OP
Hey guys just wondering what kind of lockers/limited slips fit in the front of a gen1. Also what kind of fluid do the rear axles, t-case and trans take (type f or dexron 3). I tried the search function but i couldn't come up with anything.
89 dodge raider v6 auto 235/75 15 wranglers
88 dodge raider 4 banger stick
gotta get a little mud on the tires
Re: Locking up the front end [Re: redraider] #845554 11/05/07 09:55 PM
heathdogg Offline
The Trans fluid for the auto will be on the dipstick. It should say diamond-spII or sp-III. Some say to use dex III, but I don't trust it. The Manual trans and transfer say to use a 75-90w GL-4 or higher spec and GL-5 spec in the diffs.
Re: Locking up the front end [Re: heathdogg] #845555 11/05/07 10:03 PM
Mad_Scientist Offline
Definitely mitsu auto trans fluid <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Locking up the front end [Re: redraider] #845556 11/05/07 10:06 PM
Searching for:
+front +locker = lots of hits
+front +lsd = lots of hits again
Locker is ARB, not sure if there is one for the 4-cyl, I think just the V6.
LSD options are based on StarQuest rear diffs and varies between years on what to mix-and-match.
Re: Locking up the front end [Re: MontyMcV] #845557 11/05/07 10:28 PM
sparkem Offline
I think the owners manual says to use Dex2 or 3 in the gen1 auto tranny. Tcase and diff is gear oil. If a LSD in rear, you are supposed to put some additive.
Re: Locking up the front end [Re: MontyMcV] #845558 11/06/07 12:20 AM
CapnCrunch Offline
The only ARB front locker available for any Montero is the RD110. It will fit any Gen I V6 front diff and many Gen 2 V6 front diffs. It will not fit the 4-cyl front diff, but a Gen I V6 front diff, mounts, and CV axles can be swapped into the front of a 4-cyl rig fairly easily. When I did this I had to get my front drive shaft shortened about an inch an a half.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Locking up the front end [Re: CapnCrunch] #845559 11/06/07 03:06 AM
Righteeo Capn. And for those inclined to do the front axle swap, grap yourself the break booster from the donor while your're at it.
For the GenIIs, I think the larger front diffs are mainly in 3.5s. Also in MT 3.0 SOHC 24Vs. (And we know how few of them there are. <img src="/forums/images/graemlins/smile.gif" alt="" />)
Re: Locking up the front end [Re: redraider] #845560 11/06/07 03:31 AM
DirtDriver Offline
Diff lubricants recommended when ARB lockers installed:
Normal/Typical
Shell: Diff Oil (SAE 90)
Mobile: Mobilube GX90
Heavy Off Road Use
Shell: Spirax HD 85W-140
Mobile: Mobilube GX140
High Temp/Desert Use
Shell: Spirax S 80W-140
Mobil: Mobilube SHC 80W-140
Low Temp/Winter Use
Shell: Spirax S 75W-90
Mobil: Mobilube SHC 75W-90
Courtesy of ARB Locker Operating & Service Manual
Notice no friction modifiers in the rear when an LSD is upgraded to a locker.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Locking up the front end [Re: DirtDriver] #845561 11/07/07 04:03 AM
powerRam50 Offline
or you can weld the front locked.most peaple hate it but i like it.
Re: Locking up the front end [Re: CapnCrunch] #845562 11/10/07 09:28 PM
The reason I asked was because I went to the ARB site and it said that the RD110 Will not fit into the gen1 v6 front axle. That and I wanted to be sure before I bought one and set it up.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6404 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-06-17 13:27:14 UTC
