pulling intake manifold #845567 11/05/07 09:14 PM
F
Fishingfool Offline OP
cant get the intake manifold off. trying to do a head gasket - timing chain job on '87 22RE engine. removed all the 8mm bolts and 2 8mm nuts and tapped on it with block and hammer. no go. i dont want to crack the aluminum casting with brute force...
Re: pulling intake manifold [Re: Fishingfool] #845568 11/05/07 09:19 PM
4Crawler Offline
Did you remove the 6mm allen head bolt under the thermostat housing?
Re: pulling intake manifold [Re: 4Crawler] #845569 11/06/07 12:08 AM
F
Sounds like that is the problem. I didn't read anything about a bolt under the thermostat housing, but there's a lot they leave out of the aftermarket shop manuals. thanks, I'll check it out when I get home.
Re: pulling intake manifold [Re: Fishingfool] #845570 11/06/07 03:09 AM
toyneedshelp Offline
i hate that bolt!!!
Re: pulling intake manifold [Re: Fishingfool] #845571 11/06/07 03:16 AM
kewlynx Offline
6mm
FWIW, the 93 FSM at the top of this section will ballpark you on your 22RE work. Just be aware info for the 3.0 is in it also, so pay attention to your specs. <img src="/forums/images/graemlins/kewl.gif" alt="" />
All the aftermarket books are good for are kneepads and outhouse reading.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-06-23 13:05:46 UTC
