removing '87 yj speedo needle #845622 11/06/07 01:58 AM
bhartwell59 Offline OP
can the speedometer needle be removed? if so, how?
it doesn't seem to be something i can gingerly pry off.
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: removing '87 yj speedo needle [Re: bhartwell59] #845623 11/06/07 02:38 AM
BigJim Offline
Why does it need off?
Re: removing '87 yj speedo needle [Re: BigJim] #845624 11/06/07 02:58 AM
the tripmeter broke last week... and since i have an extra speedometer i was hoping to swap out the tripmeter works and drop it into this other speedo.
but there are two screws holding the tripmeter works in place on the speedometer and i can't get to them without removing the face hence the need to remove the needle.
Re: removing '87 yj speedo needle [Re: bhartwell59] #845625 11/06/07 04:32 AM
BigJim Offline
You have to peel that can open.. from the back you can put in any parts you wish. You may even see what is wrong with your trip thingy.
It takes a little persistance but once open you can get to anything you want.
Re: removing '87 yj speedo needle [Re: BigJim] #845626 11/06/07 02:37 PM
you're right about persistence i got it figured out.
just unscrewed the two screws holding the face in and twisted the face until i was able to fit a small phillips through either the odometer or tripmeter openings and popped the new tripmeter works in.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6039 MB (Peak: 0.6680 MB) Data Comp: Off Server Time: 2026-07-14 10:49:11 UTC
