missing #845627 11/06/07 03:04 AM
A
ak92toyota Offline OP
i have a 92 pickup with the 22re i just put a new long block in it runs good with lots of power but is missing at about 2500 to 3000rpms in all gears only not under a load if you are speeding up or push the gas pedel down it goes away any ideas timing is a 5 deg valves are 8 and 12 thanks
Re: missing [Re: ak92toyota] #845628 11/06/07 03:07 AM
4Crawler Offline
Might be the EGR valve opening up at the wrong time, perhaps due to hooking up the vacuum lines feeding it improperly. For a quick check, try plugging the vacuum line to the valve itself. If missing goes away, fix the EGR plumbing.
Re: missing [Re: ak92toyota] #845629 11/06/07 04:53 AM
rexburg22re Offline
when mine did that it was the TPS... try calibrating that as well.
Re: missing [Re: ak92toyota] #845630 11/07/07 03:11 AM
A
i checked the egr plumbing it is all ok ill check the tps adjustment tonite thanks for the help
Re: missing [Re: ak92toyota] #845631 11/14/07 02:49 AM
A
the tps is right still having problem. Any other ideas? thanks
Re: missing [Re: ak92toyota] #845632 11/14/07 02:53 AM
4Crawler Offline
Any stored codes in the engine computer?
Might check the Air Flow Meter and make sure the connector is snug:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
I had a missing issue with my '85 at certain RPMs and finally it threw an AFM code and I found a loose connector at the AFM. Fixed that and all works fine now. Missing was due to the fuel pump cutting out a little and the fuel pressure dropped.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6122 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-06-21 00:11:39 UTC
