Oil pan gasket install #845707 11/06/07 04:59 PM
TrooperII Offline OP
Ok, I purchased a rebuild kit and the oil pan gasket is a one piece gasket that follows the curve in the oil pan. But doesn't really fit the pan. What is a fix for this? should I order another one and hope its different? or just cut it off?
85 2.3 Woods Trooper (bye bye 1.9)
89 2.6 RS (really short)x2
94 Amigo
86 Troopers x2
Its really an addiction
Re: Oil pan gasket install [Re: TrooperII] #845708 11/07/07 02:37 AM
JLEMOND Offline
THERE IS NO OIL PAN GASKET ON THE 2.6 ENG UNLESS IT IS 2WD , FOR THE 4WD ENGS THE LOWER PAN (CRANKCASE IS SEALED TO THE BLOCK WITH A GOOD QUALITY RTV SEALER , YOU DO HAVE END SEALS , THAT MUST BE INSTALLED IN THE REAR MAIN SEAL CAP AND ONE ON THE FRT SEAL RETAINER , INSTALLED CORRECTLY THEY WILL NOT LEAK, DONT EVEN TRY AND USE A PAN GASKET , OR YOU WILL HAVE TO DO IT OVER JERRY
Re: Oil pan gasket install [Re: JLEMOND] #845709 11/07/07 06:12 AM
hey jerry thanks for the info. it seem like there was a gasket on the engine when I took it off. So dont use the rubber gasket and use some silicone gasket maker?
94 Amigo
86 Troopers x2
Re: Oil pan gasket install [Re: TrooperII] #845710 11/08/07 01:45 AM
JLEMOND Offline
THE 1.9 ENGINES DID USE A LARGE RUBBER GASKET BUT THE 2.3 AND THE 2.6 INLY USE THE HALF MOON SEALS AT THE END OF THE CRANKCASE. THEY MUST BE USED THERE THE REST OF THE SURFACE WHERE THE MAIN PAN BOLTS TO THE BLOCK USES SILICON SEALER, ,THE BOTTOM PAN ,THE SMALL ONE DOES HAVE A GASKET ON IT . JERRY
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6010 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-05-29 22:43:53 UTC
