99 Amigo lift #845811 11/07/07 06:23 AM
TrooperII Offline OP
Ok, so I put on the lift, and cranked the torsion bars on my Amigo and noticed the front tires are pointing outward. Assuming that it needs aligned. What if any way it there to get my tires straight?
85 2.3 Woods Trooper (bye bye 1.9)
89 2.6 RS (really short)x2
94 Amigo
86 Troopers x2
Its really an addiction
Re: 99 Amigo lift [Re: TrooperII] #845812 11/07/07 12:16 PM
TrailMystic Offline
Camber will be out when you first do a lift. Toe can also be affected. All can be corrected.
A good shop can align the toe or camber. Here is an explanation Alignment
Any shop can align the toe, but some shops will tell you that the camber cannot be aligned because you "took it out of specs" with your lift. This is B.S. A good shop CAN align the camber on a '99 Amigo without any problem.
One Firestone told me they could not do it. A new Firestone said, "No Problem" and aligned it perfectly - toe, camber and caster. I had even tire wear for the life of the tires.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: 99 Amigo lift [Re: TrailMystic] #845813 11/07/07 04:47 PM
so your saying to take it to a shop? is this something I can do my self?
94 Amigo
86 Troopers x2
Re: 99 Amigo lift [Re: TrooperII] #845814 11/07/07 06:18 PM
rodeoredd Offline
if you can do allignments, then do it yourself. if not - then take it to a shop. the fact that you are asking tells me you may be better off at a shop... no biggy; its worth it..
'99 Rodeo V6 4x4 w/ 8" lift, 33" TrXus MT
4.77, Aussie Locked rear, 8500lb winch, custom rack, custom winch bumper, ProComp lights, 230,000km
http://www.cardomain.com/ride/2231794
Re: 99 Amigo lift [Re: rodeoredd] #845815 11/07/07 10:18 PM
onebadtrooper Offline
I go to the local isuzu dealer. They didn't have a problem with my moms lifted vx, and my brothers lifted amigo.
I think it was like $70.
Re: 99 Amigo lift [Re: onebadtrooper] #845816 11/08/07 12:30 AM
TrailMystic Offline
You're fortunate to even have a local Isuzu dealer. Most of us don't have that option anymore. <img src="/forums/images/graemlins/frown.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6073 MB (Peak: 0.6774 MB) Data Comp: Off Server Time: 2026-07-14 18:34:15 UTC
