MAF sensor causing knocking ? #845831 11/07/07 08:30 AM
A
awolf Offline OP
For almost a year and a half my 2001 Tacoma 4x4 has been making pinging, knocking sounds, much like one would hear after getting bad gasoline. That might be what started this problem, who knows. For 4 years I used mid-grade gas. After the pinging started I went to premium which helped for awhile,then the pinging started back again. Over time it got so bad that any acceleration make the truck sound like the front end was loose and gonna fall out. It was very embarrassing too. About 4 months ago I went to a toyota service dept. who put in a 5 dollar can of top engine cleaner and charged me 75 dollars. It never helped a thing. Then a month later ,I went for my 120K service, thinking that getting plugs and other things changed would help. Nothing was helping and no one could tell me what was wrong. Then only 2 or 3 weeks after getting serviced, my engine light came on. Had the mass air flow sensor changed and the pinging and chattering has gone away. I've gone back to mid grade gas and everything is fine now. I just wanted to pass this along. If anyone wants to comment or add to this, I would like to read what you have to say.
Re: MAF sensor causing knocking ? [Re: awolf] #845832 11/07/07 05:43 PM
Coyotekid Offline
As far a the MAF being replaced..
It probably just needed to be cleaned <img src="/forums/images/graemlins/ignore.gif" alt="" />
Insted of forkin' out the few hundred bucks you probably did.
-Dano-
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: MAF sensor causing knocking ? [Re: Coyotekid] #845833 11/08/07 12:45 AM
BIGBURLYNAKEDMAN Offline
I agree. I was naive too, at one point, and replaced the damned thing.
A few squirts of QD Electrical Parts Cleaner makes it good as new for about $3.98. Pass that along too! <img src="/forums/images/graemlins/cheers.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: MAF sensor causing knocking ? [Re: awolf] #845834 11/09/07 02:12 AM
Dandeman Offline
Toyota Moderator
I've had a dirty MAF cause knocking on my 4Runner.. cleaning it as others suggested above fixed the problem..
Matter of fact I clean the MAF every 30,000 miles as normal maintenance..
Re: MAF sensor causing knocking ? [Re: Dandeman] #845835 11/09/07 05:11 AM
kewlynx Offline
Said 30K linky <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6096 MB (Peak: 0.6920 MB) Data Comp: Off Server Time: 2026-10-22 00:10:09 UTC
