Mazda replacement engine? #845838 11/07/07 10:13 AM
Delarey Offline OP
Heard the bad news today that one of the cylinders has low compression. There is therefor the possibility of a burnt valve or a piston thats bad. I can however get hold of a low mileage Mazda 2 liter 16 valve engine
My question now is, can I fit the Mazda engine into my Kia without any major alterations like mountings, oil pan, and so on?
Thanks for your help.
Re: Mazda replacement engine? [Re: Delarey] #845839 11/07/07 11:47 PM
DEFBOY35 Offline
if it is the dohc fe3n then it should go no problem, you just need to swap the thermostat to the opposite side i believe and use the kia intake and stuff. other than that the engines are identical from what i have read.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Mazda replacement engine? [Re: DEFBOY35] #845840 11/08/07 05:44 AM
Delarey Offline OP
Yes it is the dohc fe3n. I'll check it out and thanks for your reply <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Mazda replacement engine? [Re: Delarey] #845841 11/09/07 01:49 AM
DEFBOY35 Offline
do a google search for solomiata, he has the info regarding the swap to a rwd layout on his page.
let us know how it turns out!
Re: Mazda replacement engine? [Re: Delarey] #845842 11/11/07 01:43 AM
bombardj1 Offline
? if the FE3N motor is the same as the Kia can a mazda engine repair book be used ?
Re: Mazda replacement engine? [Re: bombardj1] #845843 11/11/07 02:41 PM
Delarey Offline OP
Interesting question. We'll come to the bottom of it yet.
Re: Mazda replacement engine? [Re: bombardj1] #845844 11/11/07 04:24 PM
DEFBOY35 Offline
i couldnt see why not. I believe the intakes, throttle bodies and the injectors aree different. but everything else is the same.
Re: Mazda replacement engine? [Re: DEFBOY35] #845845 11/11/07 05:59 PM
fokion Offline
And maybe transmision bellhousing... but that is NOT from first-hand experience..
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6220 MB (Peak: 0.7038 MB) Data Comp: Off Server Time: 2026-06-07 08:40:16 UTC
