front diff or hub problem #845975 11/08/07 03:41 AM
V
v8yota Offline OP
93 toyota x-cab,,22re 5 speed,,,i went out 4 wheeling this past weekend and after a while,,the front end started to make a grinding noise and squeeking noise every once in a while,,,every time it was under a load (going up a hill or on the gas) the noise went away,,,the 4 wheel drive still worked great,,,,it even made the noises when i was rolling in neutral ,,,at the end of the day when i got back to the street and unlocked the hubs it was perfect with no noises at all,,also now i noticed that when driveing down the road my steering wheel shakes back and forth a little bit,,,,,,,,,,,thanks for any help
Re: front diff or hub problem [Re: v8yota] #845976 11/08/07 04:55 AM
P
philly Offline
was the sound coming from both side? i would just think to take the hubs off and grease them nicely.
Re: front diff or hub problem [Re: v8yota] #845977 11/08/07 04:59 PM
OOP'S Offline
Could also the bearings/bushings (they came with both)in the spindles need to be greased.
I really doubt it is the hubs, once they are locked in there are no moving parts. It would be more likely they would squeak when they are unlocked.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: front diff or hub problem [Re: philly] #845978 11/08/07 09:53 PM
V
v8yota Offline OP
i really do not know what it is,,,it sounds like it is the driver side,,,all i know is that when i unlock the hubs it is good,,,and when the 4 wheel drive is under pressure it is good
Re: front diff or hub problem [Re: v8yota] #845979 11/10/07 04:48 AM
V
v8yota Offline OP
anybody
Re: front diff or hub problem [Re: v8yota] #845980 11/10/07 05:34 AM
F
flyinhawaiian Offline
sounds like you need to do a teardown and look for shiney areas. I recently had problems with lt & rt hubs (sfa) and it turned out to be the inner hub seal. there is a round spring in the seals which causes the seal to squeeze around the spindle. well the spring somehow came out and was grinding between the hub, bearing and spindle. try grabbing the top of your tire and push it in and pull it toward you. mine you could feel the play. after the new seals, it was sweet. just my 2cents.
Re: front diff or hub problem [Re: v8yota] #845981 11/10/07 06:10 AM
OOP'S Offline
I gave you one suggestion. Tear it down, it will not fix itself.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6133 MB (Peak: 0.6874 MB) Data Comp: Off Server Time: 2026-07-16 23:11:59 UTC
