A/T light & some other stuff...... #846010 11/08/07 02:05 PM
Baldylocks Offline OP
Been a while yaÆll. My Monty has been running fine until last night. The A/T light came on a few weeks ago. I just need to know where the SW is located. I will replace that.
But I was doing the old ôstart it up and let it run a whileö thing. I use it for hunting and havenÆt been in a while. It ran for about an hour with the running lights on. I was checking out the heater and the lights because I am bringing it to Odessa Texas on a big hunting trip. I turned it off, tried to re-start it and the battery was completely dead. The instrument lights wouldnÆt even come on. I recently replaced the battery and the alternator. This is the first time I have had any problems with this since the replacement. Would letting it idle for a long period cause this? Let me know what you think.
Thanks
Pat
1990 MonTERROR
183.07 cubic inches of worn out FURY
New ALTINATOR
And uh... new radiator hoses UPPER AND LOWER,
SAGGING COILS, dead SHOCKS
Worn 29 x something x something else STREET TIRES
GET SOME
Re: A/T light & some other stuff...... [Re: Baldylocks] #846011 11/08/07 03:48 PM
shadowgear Offline
Hey,
It might still be a bad alt. Just because it was replaced, doesn't mean its not defective. Have it tested. Here is the link for the article in the tech archives for the inhibitor switch:
http://www.4x4wire.com/mitsubishi/tech/inhibitor_switch/
Hope this helps and good luck with the fix <img src="/forums/images/graemlins/cheers.gif" alt="" />
'88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Dead
'88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install) - Still Kicking.
'03 Monty Sport - XLS, BFG A/T's - Dead
Re: A/T light & some other stuff...... [Re: shadowgear] #846012 11/08/07 07:40 PM
8
89IsMine Offline
I second the suspicious alternator. I had mine replaced with a Bosch unit when the voltage regulator fried and allowed my battery to over-charge. The first replacement unit failed within 1/2 hour of installation (happily, the mechanic was driving it, not me). The second unit failed ~6 months later... fortunately still under warranty. It is no longer under warranty now... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Eric W.
Re: A/T light & some other stuff...... [Re: Baldylocks] #846013 11/09/07 02:20 AM
rapha Offline
There is a little sensor at the top of the AT that I had to replace in order to get the temp light to go off. (assuming that the transmission is not actually overheating of course) It was a five minute job. If I remember correctly it is on the passenger side top. Takes a small wrench and just screws out.
Someone else can post up if my memory is wrong.
Carlos
'05 Frontier, Auto Tranny, 4.0 V6, 2WD <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: A/T light & some other stuff...... [Re: rapha] #846014 11/09/07 02:45 AM
89montero Offline
anyone know the part number and cost for the AT sensor? Mine broke a month ago when I went through a mud hole so the light just stays on.
1989 Montero 4dr V6 3.0l
Re: A/T light & some other stuff...... [Re: 89montero] #846015 11/09/07 02:14 PM
Thanks for the info guys. The light just stays on. Come to think of it i was going thru some deemud as well. So the sensor is at the top of the trans. Thanks again.
Pat
1990 MonTERROR
New ALTINATOR
GET SOME
Re: A/T light & some other stuff...... [Re: 89montero] #846016 11/09/07 05:56 PM
heathdogg Offline
The number is MD60933. I had to go through the dealer to get it. Just be warned. Some fluid will come out when you change it. I had the same problem with the light staying on even when cold out (32degree F even).
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6172 MB (Peak: 0.7120 MB) Data Comp: Off Server Time: 2026-06-07 09:07:13 UTC
